WIDEBAND AFR GAUGE ????????????
Been thinking of one of these,c @b can you supply
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=013
cheeRS stu
cheeRS stu
Sponsor
http://www.zeitronix.com/Products/zt2/zt2.htm
ive had a lm1 and lc1a plenty off them this has been brilliant
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
AEM Wideband - Around £200 if you get them at the right price.
Mega accurate and reliable, come with a top of the range bosch sensor, all the wiring, all the calibrations, different backgrounds etc.
Proper bit of kit. Even The Diva was impressed
Innovate LC1 controller + DB/G2/G3 gauge kits work and look well for a permanent installation, fair price too IMO at £180ish for full kit.
http://www.grahamgoode.com/innovate/db_ga.html
Testing the future
Sponsor
Innovate is hands above the rest.
OE industry is looking into their patented controller for tighter control than they have currently due to the speed and accuarcy the unit works at.
Sponsor
really im suprised at that as i thought i was the only one in the uk with these faults , sent loads back and the last got launched at the garage wall and brought a ziextronic
"Thats odd sir, weve never heard of that happening before!!"
Read up on the Innovate forum last night & it recommended I did a full re-calibration - free air & heater.
Did that this morning before I came to work & fingers crossed it seems to be ok so far.
I think I'll be buying a spare Bosch lambda though as it sounds like these do go pretty regular.
Something that I did find interesting though it that they state that you shouldnt leave a lambda sendor in an exhaust system thats NOT connected to a guage etc as this can fuck the sendor very quickly!!
it's wierd that the Lsu4 sensors appear to be so unreliable in conjunction with the innovate kit, as they are used OE in a lot of VAG cars for example, and cause no bother at all for tens of thousands of miles...
I've seen sensor error problems on my LM1 on occasions that has been attributable purely to position in the exhaust (in a OE sensor position in a Rover downpipe for example, between two secondary pipes) we couldn't get any sense out of it at all and all indications were that the sensor was bust, but putting the same sensor in the tailpipe jig then worked perfectly
I've heard of many faults with Innovate, but ive used a few and never have any problem. Mine's been on the S2 for over 2 years now, driven daily and it's faultless. it could be a build quality issue, possible with heater current overcoming the wiring - just a random guess. They also won't work with a sensor that is to far 'gone' - the detecting logic could be a little too sensitive. Still, the measuring principle is second to none, and it's this the OEM's are looking into.
Rick.
Rick.
SO, how often is it recommended that you change the sensor to ensure you're generally not going to miss the car running lean?
Also, is there any way of having say, a wideband AFR and Fuel pressure / boost gauge connected to sound an alarm if all 3 were out of sync? (thinking Lean, lots of boost / high fuel pressure indicated lots of boost...)
Originally Posted by Alg1k
Wheres the cheapest place for the innovate sensor ???
I could do with a spare.
And that will be a bosch lsu4 or?? 5 Wire thing if I remember correct!
I am ALSO one of those people that consider buying one... I am looking at the Zeitronix kit with LCD display or the Dynojet WBCommander kit.
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
