Power Plot Graph question
Old Sep 26, 2007 | 10:46 PM
Rippers's Avatar
Rippers
Monte Geek
Default Power Plot Graph question
What would cause the dip you can see in these power plots between 4000 and 4500rpm?
Old Sep 26, 2007 | 10:53 PM
dave cos4x4's Avatar
dave cos4x4
wastegage opening/shutting.
Old Sep 26, 2007 | 10:59 PM
stage 3 muppet's Avatar
stage 3 muppet
engine decided it was time for a tea break
Old Sep 26, 2007 | 11:02 PM
ECU Monitor Enthusiast
Mapping issue
Old Sep 26, 2007 | 11:15 PM
Rippers's Avatar
Rippers
Monte Geek
So there is something a miss, thats not normal behaviour??
Old Sep 27, 2007 | 03:49 AM
yrkesman's Avatar
yrkesman
AFR plot and your ignition advance near those points would tell much.
Old Sep 27, 2007 | 05:34 AM
A tight spot in the sleeves(turbo bearings) can cause this, but it is more likely to be a lean period, just as it starts to boost, so get it mapped and it will sort it out, or at least most of it.
Old Sep 27, 2007 | 11:45 AM
Rippers's Avatar
Rippers
Monte Geek
No wonder it feels so laggy
Old Sep 27, 2007 | 11:48 AM
rapidcossie's Avatar
rapidcossie
the point from where it moves to the full boost map may be wrong.
this kinda thing sometimes happens when you fit a larger turbo, thus moving the boost threshold further up the rev range.
Old Sep 27, 2007 | 11:53 AM
Rippers's Avatar
Rippers
Monte Geek
What do I need to do to solve this, if it can be solved
Old Sep 27, 2007 | 11:54 AM
It is terrible, even a monster turbo would most likely be better than this.
I would get it on the rollers, may be nothing more than a dodgy map/maf.
Old Sep 27, 2007 | 11:56 AM
Disabled Account's Avatar
Disabled Account
Are you sure the TPS is connected/working properly?
Old Sep 27, 2007 | 11:58 AM
Rippers's Avatar
Rippers
Monte Geek
I'll take it for a spin, what should I look out for on the Pectel monitor?
Old Sep 27, 2007 | 02:53 PM
Rippers's Avatar
Rippers
Monte Geek
I took it for a drive and and couldn't feel any noticeable drop in power in that rev range, in fact the turbo felt like it came in earlier then that graph shows. I did notice a slight drop in boost in that rev range thou..
Got a rolling road day at TOTD on 6th Oct so will see how it performs then, maybe a silly question but could it be anything the rolling road operator has done as it was only a power run wasn't any tuning done etc
Old Sep 27, 2007 | 03:09 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
seen that a lot on turbo engines as they come on boost, usually just a dip in torque and power carries on rising.
there was a "nothings wrong" reason for it tho im sure?
whats the torque curve like?
Old Sep 27, 2007 | 03:15 PM
Rippers's Avatar
Rippers
Monte Geek
The torque curve was underneath
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
liamT74
Sep 23, 2015 10:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
