8 second skyline anyone
Glenn Suckling's Nissan Skyline R32 GT-R has been at the forefront of the import drag racing community for a number of years now.
The GDS Motorsport / Mag & Turbo Warehouse Skyline hit the scene running with 8-second passes all over the show, and has since run at an 8.02 @ 281kph.
Unfortunately, as is the case, all good things must come to an end, and so is Glenn's time with the car he built from the ground up. While sad news, it does mean that one lucky bugger out there has the oppertunity to get a hold of this angry machine.
The engine in the car has only run 8 passes since its rebuild. Every single pass being low 8 second passes excluding one.
The engine currently has:
A Nissan RRR engine block modified by GDS Motorsport
A Trust 2.7 litre stroker crank, rods and pistons also modified by GDS Motorsport
The engine is dry sumped with a Peterson 4 stage dry sump system
The cylinder head is modified by GDS Motorsport with Tomei cam shafts, valve springs & cam cap studs etc.
The engine has a full Trust stud kit
In the current guise the engine is producing 1417hp with 961 lbft of torque
The engine is currently tuned on VP M1 Methanol
It uses 1 SX fuel pump as a primer pump and has an Aeromotive mechanical fuel pump running off the front of the engine with an Aeromotive fuel pressure regulator and -12 fuel lines.
It runs 2 fuel rails and 12x1550cc fuel injectors.
The car runs a HKS T51R SPL BB turbocharger with bellmouth and carbon air intake system. It also runs an HKS 60mm external wastegate. The boost is controlled through the Motec engine management system.
The car runs custom driveshafts and axles throughout.
It also has a Holinger sequential 6 speed gearbox with custom GDS Motorsport ratios which is also modified in conjunction with Holinger. In its current guise it is 5 speed.
The gear lever has an integrated NZD$2000 Bosch load cell which is programmed through the Motec ECU for flat change.
Both front and rear LSD units are Cusco and also the spare engine has its own Cusco LSD unit fitted.
The bonnet, bumper undertray, interior panels, dash, headlights and boot lid are all carbon.
The car has polycarbonate windows throughout and last time the car was weighed it was 1036kg.
The front bumper and doors are fibreglass and there is a spare fibreglass bootlid.
The car has a Motec ADL dash logger with 1MB of logging
Motec M800 ECU with advanced functions enabled and duel lambda enabled
Motec CDI-8 capacitor discharge ignition system
Motec E888 expander unit running 6 exhaust pyros
All these systems are linked together through a can bus and can talk to each other.
The 4WD system is mechanical in design by GDS Motorsport. The 4WD pressure is displayed on the race screen of the ADL dash logger.
The clutch in the car is a Tilton carbon triple plate. This clutch is quite special. It has 3 lives. It is currently on its first life as I sent the clutch back prior to this season to be rebuilt in the States. I personally get two seasons out of one life.
Also there is a brand new spare flywheel and Tilton triple plate (sinted bronze) clutch which has been balanced to both engines.
The car has 6 Bogart rims and Mickey Thompson drag slicks.
The car has 8mm Wilwood brake discs with custom alloy hats and billet front Wilwood dynalite calipers and factory Nissan calipers on the rear.
Also the car has a Simpson parachute.
The list goes on and on.
Please find below a list of spare parts being sold with the car to correspond with the attached photos.
SPARE PARTS.
2x Bogart rims and new Mickey Thompson drag slicks
2x 20 litre fuel containers and stand alone flushing fuel tank
1x cooling fan
1x dyno exhaust adaptor
1x gear lever with Holinger ignition cut gear knob
1x boot lid
1x fuel rail
1x crank angle sensor
1x radiator and cooling fan
1x front and rear springs
1x carbon air intake headlight (left hand)
1x intercooler pipe for second plenum
1x Trust drag intercooler (150mm thick)
1x 4WD transfer case
Spare wastegate springs and new stainless steel valve
1x 4WD master cylinder with modified seals for mineral fluid
1x flywheel and Tilton triple plate (sinted bronze) clutch and release bearing (all new)
1x LSU lambda sensor
1x new cam belt (high strength)
1x new alternator and fuel pump belt
1x new dry sump belt
Spare engine gaskets and seals
Spare front axles (2 complete with GDS Motorsport spec axles)
Spare rear axles
Spare rear diff with custom GDS Motorsport drive flanges and Cusco LSD unit
1x GDS Motorsport spec rear driveshaft
1x front driveshaft
2x new Apexi drag head gaskets
4x sets of new race spark plugs
Spare oil filters and engine oil
1x dry sump tank heater
1x battery charger (fast charger unique to the car)
Comprehensive range of second hand Holinger gear ratios
1x full set (new) Holinger gear ratios, 4x new dog rings and 2x new 3rd-4th gear selector fingers
1x spare second hand engine comprising of:
2.6 litre engine
Tomei crankshaft
Tomei con rods 22mm pins
GDS Motorsport spec JE pistons
GDS Motorsport spec head
Tomei camshafts
Tomei cam cap studs
Tomei valve springs
The engine has a full set of ARP studs
Engine also dry sumped
Front diff has a Cusco LSD unit
Centre axle is custom GDS Motorsport spec
The last dyno run for this engine was 1289hp but the tune was refined at the dragstrip with the last run before I removed the engine was a 8.18@174.77mph.
If you would like to see a full gallery of images of what you get please goto: http://www.magandturbo.com/pages/4sale/skyline
There is extensive video footage avalable here:
mms://219.88.243.186/intpic/mtpromo01.wmv
http://www.magandturbo.com/pages/doc..._glen_high.mov
http://www.youtube.com/watch?v=yjV2ddUaJGE
http://www.youtube.com/watch?v=DNMpGbjcbcs
http://www.youtube.com/watch?v=t18Z4VGtCkw
http://www.youtube.com/watch?v=PwnbxqkjLCQ
http://www.youtube.com/watch?v=n75HjFcDyYY
