bd16 and bd14 with t34?
ok got a question
i got all my head back on ast night for the car to last about 10 miles before a serious misfire and lost all power i just made it home
found out that 1 and 2 are full of oil and the gasket is leaking from front corner
so now im going to get my engine built but
i want to spec it for around 450-500bhp but it will still be on greens and t34 for the time being untila later date when i can get the injectors and turbo
so was wondering what it would drive like with bd16 and 14 cams in with a t34
obviously the engine will be low comp with pocketed pistons all balanced and the head will be ported etc
any ideas or should i just run std cams
*** Sierra RS Custard ***
It will be horribly laggy without any top end.
For 450bhp you dont need a BD14/16 anyway, why have you gone for those cams???
Just run the standard cams for now definately, and seek advice on the cams for 450bhp as I think you have gone too hot, especially on the exhaust side
dont know who is mapping it yet either stu or karl
but as i said i would like the engine specced for good power but not used until a later date
and thought the cams would be wise to fit in while the engine is outm but now thinking they can be done anytime lol
also a question iskys ive heard you need the head machining to fit them, but is it the hea dor just the spring platfroms that the springs sit on?
Originally Posted by staffi
Originally Posted by xr4x4rs
i dont mind a bit of lag tbh
You can buy my T38 off me then in 2 months time... just made 442bhp..
You know i wouldn't let you down Paul..
Now are you sure you could handle 440+??
lol
im in 2 minds at the minute on what to do
been having a good think about this afternoon
do i rebuild it?
just get another engine froma breakers and leave it stage 3
or do i break it
do i rebuild it?
or do i break it
Well you COULDN'T be anymore unsure..
If you feel like that then i'd advise against spending lots of money on it.
leave standard cams for know as they easy to swap later and as for valve springs i thinx there some on reyland website that do not require any machining and they are double valve sprigs hth
i am unsure yes
90% sure its not going to be broke
so i either get another engine and bang it in and leave it stage 3 or rebuild mine
problem is this is my only car!
so im sort of thinking of gettin another engine and rebuilding my lump if you know what i mean
im just a bit gutted after soending so long building it and doing everything correctly for it to go after 3 weeks and then more money to try and solve a problem and its fukts up again
bd16 is too big to run with greens and T34! standard cams will do fine just make the double spring valves and make the cams later when you decide to make a T4 and greys!!!!!
Russ Payne
25-09-2015 08:29 PM
