Who runs a Pectel T6 and could check something for me?
#81
Originally Posted by Flux Capacitor
polly_x,
Have you tried reversing the crank sensor pins![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
#86
polly_x,
That may be the ecu just counting transitions.
The direction off them WILL affect syncing.
The ecu will part sysnc WITHOUT the cam/phase sensor
#87
polly_x,
#89
polly_x,
The rpm calculation just counts the fact it has happened NOT the direction
of the signal itself. Changing the pins round may correct that issue.
You should still get a sync without the cam sensor working although it
may flag up an error after a few cranks.
I still think you have an issue with the crank signal in its polarity or the
teeth spacing or the material its made from assuming the number of teeth
and crank sensor type settings are as you confrimed earlier.
#93
the Spark is just the coil discharging after being switched on for 48 hours continuously...
Just as a point stu....did you invert the wires on the phase sensor?
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#97
Originally Posted by GARETH T
yes,,, its just comes up with a sync error i think
So my point about the crank sensor is valid yet no one listens LOL
#105
What did you do to fix it ?
now get it mapped and too a trackday,, so i can blag a ride
#108
Got to go out now.....so I guess its fun over for today.
Simon, you win todays prize for solving the spark issue.
Its a night with Gareth!!!!!......Hope your Fat?
Cheers everyone!
Cheers everyone!
#110
Cheers everyone!
Cheers everyone!
I am not fat but thats ok, Ive had him allready
#112
Still not running...............
But I didnt try tonight.
Decided to do some of the last finishing off touches like wiring the Oil Pressure, Oil Temp and Fuel Pressure into the ECU and making sure it was transmitting to the dashboard.....Which it is.
Tomorow will be get it running and ready for mapping day.
I will no doubt have problems and the winner of the problem solving will get the chance to show Gareth their tools.
#113
Just to poke my nose in and add a few markers
to go to T6 from P8 you correctly have to invert the phase wires
Also if running rocker cover phase sensor, on a P8 it runs 2 triggers, on a T6 you run 1.
Also with T6 you DO need to see if a 36 minus one crank pulley was used.
and lastly is the loom and crank signal wired for twin sensors.
oh correct map sensor?
Any other Questions please PM or e-mail me, I have lots of Pectel drawings, and love getting my teeth into this stuff.
#116
And or the difference in the wiring between a 5 and 3 bar map sensor....I had one couple of years back....you have to swap two wires on the plug...
Cant believe the car still wont run.......
#117
hi ian, he thinks its a map issue or maybe timing.
as the map is for greys and he's running 850CC's
so i think he needs to a % cut on the fuel map or something i think he said.
Stu can't get near a PC today.
#120
ian, it cranks and spultters but doesnt catch to run if you know what i mean.
Tony, yeah thats what stu said.
Sure its something minor and a bit of adjustment and the car should be running tonight.
