what exhaust housing for 500hp? also, wastegate size?
Old 05-09-2007 | 09:41 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default what exhaust housing for 500hp? also, wastegate size?
...on a gt3076r? would the .63 do it, or will i have to go for a .82? i'm hoping to keep around a 8:1compression ratio.
also, any idea what size external wastegate i will need to use?
thanks
Old 05-09-2007 | 09:43 PM
Gordon1's Avatar
Gordon1
i would go for .82 much better than the .62 on that turbo
Old 05-09-2007 | 10:08 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
IMHO never ever go for the smallest, very little to gain, and a lot to lose.
All GT's were designed with the middle ex housing option in mind.
Old 05-09-2007 | 10:22 PM
Turbo Zetec
Engine Machinist
i was swaying toawrds the .82 anyway and probably a 40mm wastegate
Old 05-09-2007 | 10:25 PM
Gordon1's Avatar
Gordon1
40 or 44mm
Old 05-09-2007 | 10:33 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
You will no doubt be running tons of boost (well, a good 2bar) so wastegate size wont be a big deal, not unless it mounted in a way that impeeds flow to it or summat.
Old 05-09-2007 | 10:36 PM
Gordon1's Avatar
Gordon1
very true
Turbo Zetec
Engine Machinist
wahts the best way to mount it on a cossie? i've seen cast trousers with w/g outlet on one side, i've also seen them with the outlet welded onto the centre. any ideas? i'm hopefully not going to be running masses of boost... although....
Old 05-09-2007 | 10:51 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Id rather be running masses of boost than the other option, which is a high revving wild cammed mega ported giant turbod thing, which would get you the same power at less boost, but fuck all torque and no decent power for ages up the rev range.
I dont get why people think boost is bad.
Old 06-09-2007 | 06:45 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
use the 63 ,no loss of power and quicker spool up,with a 44 ex wastegate.
Old 06-09-2007 | 09:22 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
2 bar of boost and 8:1 c/r = shed loads of ignition retard (single figures on the top line, which will put HUGE amounts of heat into the engine) or BANG!
Tank Mike
Ford Focus ST Parts for Sale
18-05-2016 10:38 PM
alexbarnes95
11
15-09-2015 11:26 AM
Mk5brown
09-09-2015 01:52 PM
