View Poll Results: live map or rolling road
live map
72.97%
rolling road
27.03%
Voters: 37. You may not vote on this poll
Live map or rolling road tuning????????
Old 05-09-2007 | 11:47 PM
  #41
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
...sorry you not getting me...or not reading my replies...live map at a test track only..i dont condone a live map on the road!....i agree a rr map is fine if you dont drive flat out on the road..which you wont as you are all pedestrain conscious
Old 05-09-2007 | 11:50 PM
  #42
escossie560's Avatar
escossie560
now you have lost me as why would i not be able to run flat out because my car was mapped on the rollers could you explain please in idiot speak as im clearly having a dumb moment
Old 05-09-2007 | 11:51 PM
  #43
Deleted by Request
Former Sponsor
...a rr can not recreate real world..its a false world...like fake tits they go wrong in the end
Old 06-09-2007 | 12:00 AM
  #44
escossie560
You argue against dyno mapping but 2 of the people for it have record holding cars so can not be all bad, in some ways you make sense and i agree with the fact that an engine dyno is the most acreate way but not every one has access to one.But i do think that as far as live mapping goes it is a long way behind chasis dynos as loading can be adjusted and conditions are replicated apart from airflow but thats where compensation tables come in to play. As even road conditions vary surely.
Old 06-09-2007 | 12:32 AM
  #45
Twellsie's Avatar
Twellsie
here is my thought (it may not even be slightly right, as i am not a mapper/tuner)
I would have thought that mapping live on the road would enable you to produce a car that feels more drivable, as it is conducted under real road conditions.
BUT if you are after out and out power, the only way you can do it is to have it on a RR, where you can measure any increase/decrease in power any adjustment you make
Old 06-09-2007 | 07:29 AM
  #46
Bosch_Dealer should be a drug dealer, as it sounds like he is on something.
What a complete load of complete bollocks he talks.
When cars are road tested afterwards by big names in F1 for instance it is due to VARIABLES that cannot be so accurately controlled in most rolling road cells, altitude being one of many as air is thinner.
Cars like F1 are adjusted for bias towards high rpm/power or low rpm/power depending on track, whether it has more or less turns one way or the other, radius of turns etc.
For 99.99% of road cars ROLLING ROAD is best you will get, unless people can control the weather, which is unlikely, you set a car for max power when it is raining, you have less when it has stopped raining, and therefore do not maximise your true potential.
You can also control the temperature in most(good) cells(rolling roads), the operator is THE most important guy a bad one will kill your engine.
The real sophisticated cells are FULLY climatic, which you have no hope in hell of being able to replicate on the road, unless you wait a complete year!!
You can hold at steady load or speed or rpm AT FULL THROTTLE in a cell which you cannot do on the road.
Old 06-09-2007 | 10:25 AM
  #47
Garage19's Avatar
Garage19
live mapping can only represent real conditions...a rolling road is only a diagnostic tool.....
...ALL rolling roaded cars mapped will blow if held flat out.
You don't half talk some shit sometimes!
Old 06-09-2007 | 10:30 AM
  #48
GARETH T's Avatar
GARETH T
i totally agree with you,, and just out of intrest, have you seen the new F1 transient dynos? serious cool bits of work
Old 06-09-2007 | 11:33 AM
  #49
Deleted by Request
Former Sponsor
...lol..
...lets bring F1 into the equasion..a multi billion pound organisation
...i was talking more about air flow tbh...and you can only get that on the road or a wind tunnel...surely you dont beleive a rolling road can accurately predict the air flow from a small fan in front of the car?
...the dyno should be the first call if you have no base map...or if not avalible a rolling road will do....then you test track live map it to get real life.
Old 06-09-2007 | 12:11 PM
  #50
Bobby Singh's Avatar
Bobby Singh
I would say u need a base map (taken from a RR or engine dyno) from which u can alter on the road/test track.
Old 06-09-2007 | 12:56 PM
  #51
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Phil, an engine can only consume a certain amount of air, this isn't a limitless thing. Consider the size of your Turbo inlet and/or air filter. What's the point of trying to get a RR fan than blows at 100,000CFM when the engine can't process this amount of air anyway?
In other words, a fan of decent size can almost certainly supply enough air for what the engine needs. The difficult factor is whether the fan can keep the car within operating temperature in terms of coolant and also keep the inlet air at sensible temperatures. Our's can. It is more down to the indivdual car though to be honest. A car that has cooling troubles on the road, will have cooling troubles on the dyno and vice-versa. The fan size really only governs how long you can hold a car steady-state or how many consecutive runs you can perform.
However, this is fairly easily overcome. We, like most tuners, don't continue mapping as the coolant/inlet temp rises and rises, we obviously let the car cool down, just as you would on the road. As long as these factors are within the cars normal operating temperature range and the engine is getting enough air, how can there be any downside of RR mapping?
On the plus side, how can you, on the road, hold the car on one particular load-site on a map and make adjustments while monitoring the difference it is making, without crashing?
Old 06-09-2007 | 02:04 PM
  #52
foreigneRS's Avatar
foreigneRS
Testing the future
make your mind up christian if your fan is big enough the coolant temp and charge air temp would not rise.
Old 06-09-2007 | 02:12 PM
  #53
AndyRST's Avatar
AndyRST
I think Christian is on about the difference a PROPER air to air intercooler/radiator combination and that of a RS Turbo
Its car dependant, if their massive fan is fine on a car with both good intake and water cooling then tht can do more runs, if the car struggles with intake and water cooling on the road then they have to let the car cool down.
Old 06-09-2007 | 02:15 PM
  #54
Christian and Beccy
#1 in Spelling Club
As Andy said. The need for us to have a larger fan would only mean that we can carry out longer mapping sessions. This has no effect to the customer, only higher mapping prices due to the higher running costs of the RR.
Old 06-09-2007 | 02:40 PM
  #55
foreigneRS's Avatar
foreigneRS
Testing the future
i get you
JK12
33
26-04-2021 01:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 02:03 PM
05-11-2015 09:12 PM
`spotty
26-09-2015 12:41 AM
JamboRS
28
14-09-2015 10:02 PM
