Quick help needed please!
Old Sep 5, 2007 | 05:43 PM
Drewman's Avatar
Drewman
Default Quick help needed please!
Fitting the following starter motor to my 1.6 Zetec Escort and just want to confirm where the wires go.
There's a double ford clip type jobby which can only bolt on one way (top and right nuts) but where does the cable from the alternator go? Top bolt?
Thanks
Old Sep 6, 2007 | 06:54 AM
Top bolt in picture is connected DIRECTLY to battery so the alternator wire(charge lead output) can go there, if wanted.
Old Sep 6, 2007 | 07:18 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as above
starter motors are simple things. you have the motor at the bottom. that is connected on the + side to the solenoid on top, and on the - side to the engine block that it is bolted to
the solenoid is basically a switch for switching high current. you take the + from the ignition switch to the solenoid which then switches on the + directly from the battery to the motor
hope that helps
matman
Sep 9, 2015 05:45 PM
TomPengelly
13
Aug 22, 2015 06:38 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
