id 4x4 front diff, with pics
Old Sep 1, 2007 | 01:52 PM
Fil's Avatar
Fil
ELASTIC BAND
Default id 4x4 front diff, with pics
help whats it off? 90% sure its an xr4x4 2.9 one? but a slim chance its from a 4x4 sapphire cos? how'd you tell? cheers
Old Sep 1, 2007 | 02:41 PM
xr4x4rs's Avatar
xr4x4rs
the 2.9 xr and the cos are the same mate as they have the same ratios
only the 2.0 dohc are different in ratios
Old Sep 1, 2007 | 02:43 PM
Kelv's Avatar
Kelv
Almost there!
have you managed to check the ratio atall yet matey?
Old Sep 1, 2007 | 02:47 PM
Fil's Avatar
Fil
ELASTIC BAND
ahh, any idea on the ratio?
Old Sep 1, 2007 | 02:50 PM
xr4x4rs's Avatar
xr4x4rs
erm
i carnt remember
im sure someone will know the std ratio of a cos diff i think its 3.9
Old Sep 1, 2007 | 02:51 PM
allsteel's Avatar
allsteel
Ratio should be 3.6
Old Sep 1, 2007 | 02:58 PM
xr4x4rs's Avatar
xr4x4rs
thats the on
just looked it up aswell
3.6 std cos and 2.9 xr
3.9 on dohc 4x4
Old Sep 1, 2007 | 03:01 PM
Kelv's Avatar
Kelv
Almost there!
as above, should ideally be a 3.6. unless its the 2.0 DOHC!
Do you know how to count and work out the ratio?
is the bottom plate easily removable? if not you can still work it out fairly easily enough!
Old Sep 1, 2007 | 03:17 PM
Fil's Avatar
Fil
ELASTIC BAND
go on then how'd you work it out, without removing the bottom plate?
Old Sep 1, 2007 | 05:06 PM
dojj's Avatar
dojj
Resident Wrestling Legend
3.62:1 for the norm
3.92:1 for the dohc one
put a shft in either side and mark the position at the top
then mark the pionion
turn the pinion a few times and see how many turns it takes to turn the driveshafts 1 complete revolution
if it's nearly 4 then it's the dohc one
if it's just over 3 and a half then it's the 3.62:1 one
Old Sep 1, 2007 | 05:41 PM
Kelv's Avatar
Kelv
Almost there!
Just as the man said!!
Old Sep 1, 2007 | 06:10 PM
dojj's Avatar
dojj
almost forgot, you've got to make sure the shafts that are spinning are both rotating at the same time, otherwise it will give you a false reading
and you've lost the locking tab for the bearing, find it and pu it back first before you use the diff
Chas
Sep 21, 2015 08:57 PM
Caddyshack
Aug 19, 2015 07:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
COLEYST200
Aug 3, 2015 08:55 AM
Old ford
Jul 31, 2015 06:50 AM
