advise, registering a kit car with donar car reg number
hopefully someone can help me
been searching for about an hour and can`t come to a definative answer
when i come to register the rs200 i would like to keep it on the reg of the car i got my engine,suspension bits etc from
what is the criteria for it?
i know it`s points based,but how many do you need to keep donar reg?
thanks for your time,it`s doing my head in
dave
dave
It's all on a dvla site somewhere, but I am sure it's 8 points you need.
Some people have been known to tell porkies as well to keep reg plates, can't beleive it myself but true!!
Do you use the Lo-Cost builders forum????
Some one on there will deffo know the score:
http://www.locostbuilders.co.uk/index.php
I think the points sytem is required for a new reg. For the donor car reg you need the log book with matching engine numbers (if they bother to check) and be able to prove you have used the running gear (which I think requires pointing at it ).
I have my donor registered in my name, striped, registerd SORN and I have retained the chassis plate.
I havnt woried about that to much yet but there are a few builders on here that I am sure will comment.
WD
WD
8 Points out of:
* chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
* suspension = 2 points
* axles = 2 points
* transmission = 2 points
* steering assembly = 2 points
* engine = 1 point
http://www.direct.gov.uk/en/Motoring...le/DG_10014199
* axles = 2 points
* engine = 1 point
I see Thats like the new reg for a kit car.
"The registration of radically altered vehicles covers vehicles which are substantially altered from their original specification, but which are not kit conversions."
I guess its how they classify the car you are applying for
Dave,
Pop down to your local DVLA office and ask to see the person who deals with kitcar or altered vehical inspections. They should be able to give you the up to date info/forms that you need.
You will need to register the banham chassis number if has not been done, or get number for it. To get a chassis number they need to inspect it.
RB26DETT
17
27-05-2016 11:26 AM
