ipod crash ??
My ipod has just went tits up.
Its not responding to anythin and is just stuck on the one page.
Is there anyway to do a reset of some sort ??
Any help much appreciated
..BS Motorsport..
To reset iPod mini, iPod mini (Second Generation), iPod photo, and iPod (Click Wheel)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
[note: this is the tip that got it unfrozen for me]
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Mate have you tried the Ipod Slap if its stuck... Im not joking.
I had one that kept displaying the sick Ipod symbol... looked the problem up on internerd and advised the following;
Turn Ipod over so silver bit is facing you
Raise hand and slap ipod
It has worked fine ever since.
Apparently the hard drive head can become misaligned and by slapping it puts it back in the right position...
top tip
neil
top tip
neil
top tip
neil
top tip
neil
Cheers for the tip Neil but already got it working.
I'll keep that one in mind tho.
Thnkas again mate
Former Sponsor
also,
im thinking of wiping the hard drive, to clean it up,
but is it possible to load the selected songs on itunes back onto ipod, without having them on pc????
carl
carl
disco-stu
03-10-2015 08:26 PM
