Tyre question
Old Aug 24, 2007 | 12:59 PM
mk1_orion_boy's Avatar
mk1_orion_boy
Default Tyre question
What would happen if you had tyres rated for say 120mph but did 150+mph??? Would they melt? Fall apart? Pop? Or similar???
Bit of a silly question I know and I'm not about to go really fast either
Old Aug 24, 2007 | 01:06 PM
Cawood's Avatar
Cawood
why not try it n let us know
think they may not be up to the pressures put on them and just fall apart i would have thought
cant imagine they would do it on a one off but it would put a lot of strain on them n next its pop, bang, spin out, crash, died
Old Aug 24, 2007 | 01:08 PM
I have been overspeed on loads of tyres, never had a problem.
If they were Goodyear Eagle F1 GSD3 to start with they will most likely go pop anyway at any speed!!
Old Aug 24, 2007 | 01:20 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
What makes you say that?
Mine were fine at 170mph.
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
Why do you say that?
I have a set of "Goodyear Eagle F1 GSD2 215/40/16" on my car.
Old Aug 24, 2007 | 01:43 PM
Cawood's Avatar
Cawood
lol me 2
Old Aug 24, 2007 | 01:47 PM
matt p's Avatar
matt p
Oh dear!
Come on tabetha why do you say that?
Old Aug 24, 2007 | 02:22 PM
dojj's Avatar
dojj
Resident Wrestling Legend
but you've got 168.84mph in your sig
Old Aug 24, 2007 | 02:49 PM
Dan's Avatar
Dan
IIRC Christian is quite sure and has said on here that the car has done 170!
Anyway, I've got Eagle F1's, why was this said?
Old Aug 24, 2007 | 02:51 PM
Ollie MK5 Turbo
Old Aug 24, 2007 | 02:56 PM
StuarTurbo's Avatar
StuarTurbo
is it not something to do with the centrifugal forces , are the tyres only designed within a limit of sidewall flex , above this wont they "narrow" themselves ?
Old Aug 24, 2007 | 03:06 PM
gus's Avatar
gus
i did wonder this about yours the other day actually mr c, was reading the right up in performance ford about tyres
what is yours rated at then?
Old Aug 24, 2007 | 04:48 PM
Christian and Beccy
#1 in Spelling Club
I run 205/45 ZR16's.
I often wonder about people doing Top Speed runs on V-Rated tyres. I bet alot of people do, especially with these budget wheel/tyre builds around which have cheap tyres on them.
Old Aug 24, 2007 | 04:59 PM
I only said that as I have bought in the past three new goodyear eagle f1 tyres aand two of the three within two years developed sidewall bulges, so had to be scrapped.
Goodyear were useless when I moaned and said I must of hit something(kerb) with them, unlikely as one had always been a spare and never fitted, I have had pm's from others who have suffered the same with these tyres.
It is a shame as I did rate these tyres very highly, not the best by any means but in my top five anyway.
I like the GOODYEAR SUPERCUP a lot better, but F*****G scary in the wet, maybe that's why they don't import them!!
Old Aug 24, 2007 | 05:40 PM
RichieST's Avatar
RichieST
they are all rated with a factor of safety in mind. You will see on the sidewall it will say maximum pressure 50psi for example, doesn't mean it will blow up at 51psi, I think tyre pressures have a factor of safety of 2, that means they are perfectly safe at 100 psi!
As for speed ratings, I dont know what the speed rating is, but a tyre rated to 150mph should be perfectly safe for 200mph+.
Dont quote me on that though
Old Aug 24, 2007 | 05:51 PM
gus's Avatar
gus
do you know what r888 are rated at? im on 235-40-17
Old Aug 24, 2007 | 06:03 PM
CliffRS4's Avatar
CliffRS4
I think they are rated at 180 mph as they are W rated.
Old Aug 24, 2007 | 06:06 PM
gus's Avatar
gus
dont think i will get any where near that then
just over the ton will be about right for me
Old Aug 24, 2007 | 06:15 PM
GARETH T's Avatar
GARETH T
they only warrant the up to the speed rating, after that theres no comes backs on them
Old Aug 24, 2007 | 06:31 PM
sideways saff's Avatar
sideways saff
if i am right the speed rating is for a constant speed tested over a certain distance so a brief blat over the limit will be okay but kept over their limit for a time and they will deteriate quite badly quite quickly and will fall apart................i think this is right
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sep 28, 2015 06:19 PM
