Closed loop on Subarus
Old Aug 23, 2007 | 11:44 AM
JonnyBravo's Avatar
JonnyBravo
Default Closed loop on Subarus
I've been looking at a Subaru Forester recently for a mate that has a strange fault.
First thing in the morning once its run for a minute it will cut out then crank over as if it has no compression for another min ?
I put the scanner on it and noticed that the lambda was not switching much more than .7-.8 volts.
Surely in closed loop that would switch more than that ?
If you leave it for a while it will drop down to .2 then slowly rise back upto .8 again.
This is when the engine is hot and it should definately be in closed loop control imo.
I'm thinking the lambda must be faulty although I'm still suprised its fluctuating (sp) a bit.
Any advice or info on the particular car ?
It is a turbo forester btw
Old Aug 23, 2007 | 12:29 PM
AlexF's Avatar
AlexF
when cold no car runs closed loop to the exteent where the AFR is 14.7:1
Cold start needs more like 10:1
COuld that be what your seeing but it doesn t explain the fault....
Old Aug 23, 2007 | 01:21 PM
JonnyBravo's Avatar
JonnyBravo
Thats originally what I though Alex but its the same when I am driving around in it.
I was suspicious that the closed loop function had packed up on the ecu tbh.
Old Aug 23, 2007 | 01:22 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
exhaust gas needs to be at 400-600 deg c before lambda will work
Old Aug 23, 2007 | 01:24 PM
AlexF's Avatar
AlexF
Mitsy - unless its a heated sensor - they work from cold.
That function can't just pack up - it just doent.
It'll be a sensor or the wiring.
Alex
Old Aug 23, 2007 | 01:47 PM
JonnyBravo's Avatar
JonnyBravo
Sensor it is then
Thanks
Old Aug 23, 2007 | 04:20 PM
It is the switching SPEED you need to watch NOT the voltage.
Old Aug 23, 2007 | 04:32 PM
JonnyBravo's Avatar
JonnyBravo
The switching speed is very slow which is why I thought the lambda itself or ecu was at fault.
New Lambda from Subaru is Ł175 + vat
Glad I'm not paying for that
Old Aug 23, 2007 | 06:01 PM
st3v3's Avatar
st3v3
I thourght they went closed loop after 3000rpm
Old Aug 23, 2007 | 09:43 PM
daz1968's Avatar
daz1968
If you need a new lambda shop around as you can get one a lot cheaper than that, have a look on scoobynet may get some advice off there.
Old Aug 24, 2007 | 12:21 AM
JonnyBravo's Avatar
JonnyBravo
That would be open loop mate
I'm not exactly sure where is changes over but off boost (or low boost) whilst cruising is usually closed loop control
Old Aug 24, 2007 | 05:28 AM
st3v3's Avatar
st3v3
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
pabloXR
Sep 21, 2015 12:42 PM
tib2220
Sep 14, 2015 12:33 PM
