P8 ECU's...pros and cons
Rubber Rhino Crew
Hi guys, been offered a P8 from a large turbo model escos.
Is this emmisions (i thought emmisions was only small turbo but need to clarify)
And other than anti-lag capabilities what are the other advantages over a L8?
Dan
Dan
Not sure what you mean by emissions - P8 was large turbo EsCos, EECIV management on the small turbo.
Both had closed loop lambda control as std if that was what you meant?
Dan
Dan
Not a for sale post, but standard L8's and MSD wasted-spark converted L8's are always in stock and available next-day - you know who to call..........
Must admit Tony, i have NEVER seen a Faulty L8 and have seen TENS of faulty P8's, the most common being adaption failure which leaves them over rich at all points and hard reset cannot fix it.
I have seen plenty of faulty L8 Pectel CPV boards though if thats what you mean? L1 and 6 were both unreliable garbage, but i find the L8 to be the best.
Originally Posted by T S M
selling products for the l8 that the p8 does standard may lead to a biassed answer doug.
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Wasted Spark.
Closed Loop
ALS
Serial datastream. (Far better than the Pectel one too i might add)
And we can REALLY live map them, as opposed to pretending we can map them like some so called professional mappers in this country, so theres another reason we do like P8 as people choose us specifically because of this, so its not like wde slag the P8 off.
But it doesnt change the fact that the L8 is just as good as the P8 on a YB as far as i am concerned.
Originally Posted by Stu @ M Developments
And we can REALLY live map them, as opposed to pretending they can map them like some so called professional mappers in this country. ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Because Tony's bum-bag contains a real time 8 bit emulator..............
![007](https://passionford.com/forum/images/smilies/bond.gif)
The p8 ecu is extremely advance the als wasted spark and start line strategies were developed by pectel and encrypted this made copying almost impossible without huge cost .and is often why people prefer to use the older less complex ecu's to develop products for.
In 1993 the als board was 1450 and was ford motor company only the current price is 495
1 Post
i had a L8 ecu in my 4x4 saph for 3.5 years = not 1 single running problem.
i had a P8 ecu in my escos for 4 years = several problems including cold starting, hot starting and rough running amound the symtoms that were all fixedbut all ECU related none the less.
Rubber Rhino Crew
Dan
Rubber Rhino Crew
Some interesting points here.....seems like a fierce dbate which is best to use a P8 or L8..
Does the L8 ecu have closed loop as std?
If so I might just stick with the tried and tested....If it requires a mod then i'll probably end up just using the P8 as I have both so would be daft to get rid of the P8 and then have to pay for the L8 to be upgraded to the P8 spec.
All the production Escort Cossies left the factory with lambda sensor and cat'. Some very early ones had a CO trim screw on the P8 ECU, like the L8 ECU's had.
The bit about it being useless on a non-cat' model is wrong. The lambda control can be set how the mapper wants it AFAIK, but check with your tuner/mapper.
P8 with a standard chip & non-cat' may not work so well though - maybe that's what you read?
Also, some other vehicles used the P8 ECU.
EDIT: must hit submit when finished typing
Rubber Rhino Crew
So what are the common faults with the P8? and are they fixable with software or are they hardware issues?
Billabong
Right so all Escos had cats? If so how do you use the P8 in a saph for example? isnt there a sensor that signals ecu after the cat for emmisions or something?
Dan
Billabong
Dan
1 Post
1 Post
Billabong
Dan
Billabong
Dan
the factory chip uses the lambda sensor on all p8's and green top L8 cars, but not all after markey chips retain the lambda control in the software even though the cat and sensor before it are there
Rubber Rhino Crew
i'm getting confused with Green top L8's I think......I thought there were 2 different types of P8 but its the L8 that there are 2 of..the greena nd red top...
And the difference being the lambda not the cat which I was told...
Cheers for clearing it up guys.
So what goes wrong with the P8's then and if it goes wrong is it a hardware job or software fix?
Dan
Dan
always use the person not his name
THAT WHY I USING MSD FOR THE SAFF STU DO I GET A WINDOW STICKER LOL
I use super P* ECU on the RS500 and will be MSD close loop L8 on the saff !!
Rubber Rhino Crew
Originally Posted by markk
ive had P8 for 8 years and used it for competition purposes in a forrest rally car, had all options on it, duel map, ALS, WI, coil pack etc etc
never had any issues at all ! !![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Dan
super P8?
Dan
Dan
Dan
for what ever reason you want two maps, boost level, driving restrictions, test modes, fuel changes, restrictor changes the worlds your lobster ! ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
