450BHP what sort off top speed
Old 14-08-2007, 12:02 PM
RS500/364
RS500/364's Avatar
Default 450BHP what sort off top speed
When the RS500 returns
around the 450 BHP mark what would be the top speed around
8 greens T4 28psi
just wondered hope it was the clutch cable that broke not the clutch
Old 14-08-2007, 12:38 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
If distance isnt an issue you will hit the limiter in top if you got normal gear ratios.
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
An RS500 should do 175mph if on standard gearing and has suitable size wheels / tyres / high enough rev limit.
Old 14-08-2007, 01:10 PM
RS500/364
RS500/364's Avatar
Was runnig 500BHP but det started its on 17s 205/215 rear
Old 14-08-2007, 01:15 PM
Mike Rainbird
Caraholic
Was running 500BHP but det started its on 17s 205/215 rear
Aren't you on stupid high compression, so NOT surprised . I bet even at 1.8 bar the ignition is in single figures .
With 215s and standard gearing, you would need to pull just over 7200 in fifth to see 175mph.
Old 14-08-2007, 01:17 PM
RS500/364
RS500/364's Avatar
The comp is higher but wanted it to pull quicker just got to pick up the car now
Old 14-08-2007, 01:18 PM
Staffi
Staffi's Avatar
Which you did with 385 bhp Mike...........
Don't know what your gearing was like though..
Old 14-08-2007, 01:22 PM
Billabong
Billabong's Avatar
I think Mike had gearing for the overall land speed record
Old 14-08-2007, 01:24 PM
Staffi
Staffi's Avatar
Mike Rainbird
Caraholic
Staffi,
I was running 3.36 final drive, so only had to pull just over 6500rpm to achieve 172mph (which is where peak power was as well) . Don't forget the RS500 has extra drag due to the rear lip on the boot and top of the wing.
Old 14-08-2007, 01:36 PM
RS500/364
RS500/364's Avatar
RS500 slower than a three door and a saff at same spec !
Old 14-08-2007, 03:20 PM
Mark Shead
Mark Shead's Avatar
172mph max, But there is only one way to know .
Mark
Old 14-08-2007, 03:36 PM
RS500/364
RS500/364's Avatar
I not doing it on the M1
aye mark ffs
Old 14-08-2007, 04:43 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
aye mark ffs
........why not.?????
fuzzy
21
15-02-2016 10:26 PM
matman
09-09-2015 05:45 PM
Bailes1992
16-08-2015 07:14 PM
fatboy billy
03-08-2015 08:34 AM
Quick Reply: 450BHP what sort off top speed
