why is long studding bad?
#121
Originally Posted by staffi
Originally Posted by Mark Shead
Every engine I biuld over 380hp has longs studs, I dont not biuld them if they dont have them,
I do map engines over this level if the customer does not have them but in the understanding that I am not a big fan running engines like it.
Mark
Well that's mine fooked then..
and mine if thats the case
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#122
Well mine will be pushed even further in a month or so with the GT30..
HOW MUCH ARE NEW BLOCKS PEOPLE...........
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#123
Originally Posted by JonnyBravo
Sorry but something HAS to be wrong for an engine to only last 15hours IMO.
Mikes isn't mega tuned but it was a 500hp engine that done 30k, Rods old engine again was big hp and iirc that done around the same mileage with a lot of power runs.
Ofcourse I have no idea if Mark does long stud his engines though but I know Harvey does.
Really would be good for Karl to write up that article![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Mark
could you explain why this is mark ?
Mark
cheers mark
#124
at least if you are not going for long stud conversion just use the ARP bolts. Using standard stretch bolts on a modified engine will be a stupid thing to do! and it's not the first time that I hear that Karl Norris don't long stud his engines!! But I want to hear it from him personally not just people saying so!
#125
Karl isnt a big fan of ARP stud and nut kit either as he said as a few others
have also that it can crack the block! did buy some for mine but i sent
them back as i didnt want to take the risk, everybody's opinions will
differ on this subject
#126
#127
so basically it depend on the tuner as to what they personally recomend. It all seems to be down to personal preference rather than proper evidence. I'll stick with me 205 and arp's for now and see how long it last at hopefully close to 500 bup bups
#128
1st to 200 without NOS
Originally Posted by kaliber cossie
ive had 5 engine blow ups now all have been long studded blocks have now reverted back to standard engine 200block with stretch bolts grp a headgasket will let u know in time how long in hours this lasts for,
my last engine lasted 15hrs,10 long studs wrc head gasket wrc oil squirters after a while like nutter u get pissed off with the expense of replacing blocks, pistons, headgaskets( especially at Ł375 a time )
Get it built once properly and that will be it .... years of reliability rather than hours
#129
#131
sorry but I agree with the long studding
- For the relativly low expense, it is well worth doing over a set of poxy ARP studs or any other nonsense, same as the 205/200 block debate...
200 Block long studded every time for anything over 400BHP IMHO, why skimp for a few quid savings?? you will pay it out 5 times over to get it sorted.
And there will always be people saying 700BHP on a std 205 block with 2 normal head bolts is fine blah blah blah, mines not blown up yet etc etc etc, but why take the chance?? As Martin/ Sheady and any other decent tuner says, build it once, build it right
#132
Originally Posted by mechanic28
well i am going to add my 2 pence now
i have said it lots of times that imo the 200 block is no better the 205 block in a 2wd so there
![LOL clown](https://passionford.com/forum/images/smilies/smiley024.gif)
#133
My engine is 6 studded on a wrc head gasket.
Gotta re-do it and wanna go wire rung with late escos head gasket,no more
than 2 bar boost,is this feasible?
puddy
puddy
#134
puddy![Top](https://passionford.com/forum/images/smilies/smile011.gif)
puddy
#136
puddy
#137
Exscuse my ignorance, what exactly makes the block crack?? people say different things.
is it just to much power/boost ?? ![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
No one ofcourse wants to admit to it, they just say the 200 blocks crack there ! which I don't believe they just do
#138
do long studs need to be re torqued every so often. i torqued mine when i built my engine (with a snap on torqued wrench) then again after 1000 miles. now about 4000 miles later 4 of the nuts have loosened about 1/4 of a turn. now need another head gasket
. so should they be re torqued every 1000 miles or so?
#139
I`m using 4 long studs and 6 standard strechbolts. To my experience APR bolts have coused more problems than they have solved, same goes for WRC gaskets. So 4 longstuds to prevent cracking my YBD block and a group a gasket. Aiming for 550bhp.
#140
the std 200 blocks have an inherant fault straight from the factory build that causes them to crack at any decent power with std /arp studs, long studding does away with this as a by product of the long studding process. the blocks can be modded to use std studs with no worries about cracking around the bolt holes/water jacket.
#141
One thing that gives long studs a bad name is there are several inferior copies out there made from wrong material that just are not up to the job.
I found this out years ago when the one's I was supplied simply would not torque up, I now buy from a manufacturer that makes them right
#142
I found this out years ago when the one's I was supplied simply would not torque up, I now buy from a manufacturer that makes them right![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
#143
#144
#145
#147
hi lads
just my 2 pence worth but wasn't there a "dodgy" batch of 200 block that were made in Argentina ????????????
these blocks were rubbish the quality of the cast iron was a waste of time
i dont know how many of these blocks were in circulation i heard there was loads
I have has succses with both types of engines with or without long studs
the 400+bhp harvy engine had 6 x long studs with wrc gasket never had gasket failer
i aslo had 360bhp engine on a wire rung 200 block with yb0611 gasket and never had gasket failer
marco
marco
#148
#149
The quote above has you saying that a 200 block is no bettter than a 205 in a 2wd but then you go on to say that you were not saying that the 205 block is the way forward! FFS make your mind up!
The only reason for basing a big power engine on a 205 block would be the lack of availability of a 200 block but if it was me I would keep hunting for one!
#151
puddy
gasket on the rebuild,got no money
anyone got the ford part no. for the late escos gasket ?
puddy
#154
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Originally Posted by marco polo
hi lads
#155
hi lads
Didn't Rods block end up being a 99 marked block ?
#157
hi lads
