compression? and fireing order please
Old 13-08-2007, 04:04 PM
stembo21
stembo21's Avatar
Default compression? and fireing order please
Does anyone know the compression for each cylinder on an escort rs turbo engine.
any help would be great thanks.
i also need the fireing order cheeRS
Old 13-08-2007, 04:21 PM
dojj
Resident Wrestling Legend
dojj's Avatar
a bit vague that
is it standard?
do you want to know the compresion ratio?
or the compresion you get when you are running with a compresion gauge thingy?
etc
Old 13-08-2007, 04:22 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
they should all be the same, but the values will vary depending on cam specs and CR etc.
What are you getting currently?
Old 13-08-2007, 04:30 PM
stembo21
stembo21's Avatar
Its a standard engine, i just want to know what the readings should be on the compression tester
DixieTheKid
11
06-06-2020 11:20 AM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
Eigdoog
48
19-09-2015 11:03 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: compression? and fireing order please
