Anotrher diff bites the dust!
Hi guys
Down to my last 2wd diff now. Any one have any bright ideas for improving strength for the 2wd saph diff?
All suggestions appreciated!
JJ
JJ
Originally Posted by marco polo
hi mate
can get your diff or a diff re done with uprated planet gears and uprated vc to 240Nm thats should be ok
marco
marco
JJ
2Evos & 1 Escort Van :-)
Originally Posted by JjCoDeX75
Originally Posted by SiB
Go with Marco upgrade option JJ - sorted!
how much does that cost then (ps Si - did u get my PM?)
Got your PM, should still have it, but not seen it recently. Will try and find in the pile of bits that was my car (now 99% stripped!). Will report back.
ROFL - Love the idea of you being mechanically sympathetic!!!!!!
do what the americans do to the xr4ti that they have ( 2.3 turbo powered xr4i) when the put in a big power v8, buy one of these ( Ł240 at the exchange rate )
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
and mount it like this
http://www.merkurtech.com/merkurtech...dg88kit009.jpg
http://www.merkurtech.com/merkurtech...dg88kit013.jpg
do a search on google for 8.8 xr4ti, takes some finding but loads on the net about it, common convertion over the pond, and bits are so cheap.
The idea with the XR8 sounds quite fun - Ill have a look at the threads and see if I can get my head round, but lets have a look at the 9" diff thing first.
I have two sets of cossie shafts - so presumably two long shafts?, but where does the diff come from - what donor car?
Am I being thick? - it is a 2wd beam,
JJ
JJ
they do it to take standard cosworth shafts
http://www.merkurtech.com/merkurtech...h88stub001.jpg
http://www.merkurtech.com/merkurtech...h88stub004.jpg
have a look though he for loads of pic and info
http://www.merkurtech.com/merkurtech...pages/main.php
Also - 4:1 ratio - wont that make it somewhat shorter than standard? Id rather if anything slighly ratios.
JJ
JJ
JJ
JJ
JJ
Originally Posted by Kevin Sharp
heres a pic of my 9 incher girls
Wouldnt even know where to look!
JJ
JJ
JJ
JJ...unfortunateley the words cheap and 9" diff dont go together on the plus side its a straight forward conversion into a 2wd rear beam....
JJ
hi mate
i have a 7.5 Gripper plated Diff in my 3door and have not broke it yet
saying that i have a 9" x trac plated diff ready to fit
i have part ex it for the 9"
if you have the uprated Viscous coupling thats is a hell of alot better than a standard unit for better traction/handling and the uprated planet gears makes it alot stronger
the most you can uprated the standard VC plates in the 7.5 diff is 240Nm
you could always use the nickel plates which are alot thicker and you can uprated the VC even more 400Nn+ obviously more money for the nickel plates
pound for buck the uprated VC/planet gears is the way to go
marco
marco
hi mate
marco
marco
JJ
