Small Turbo Fuel Pump Help
right people need a bit of help with my small turbo escos
i have not had it long, a few months only
i want to take it to MSD, to have it tuned and chipped
it needs to have an uprated fuel pump fitted
how can i check if it already has a pump in it, its stage1 at the moment and someone said it should have a pump in it, if its stage1
can anyone help please
also what is the small turbo like with 305 setup/chip
is it any good, or am i better going down the big turbo route
i only want the car to be fast point to point really
its inside the tank,so you will have to get it out to see.
good pumps which supply a lot of fuel have a goodridge fitting on the top of the pump and you could see it if the tank is dropped a bit.
there might be a goodridge hose connecting the pump to the fuel filter,this you will see easy.
to go the big turbo route will cost a lot and maybe not worth the exta money.....depending on what power you want really.
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
