COSWORTH IDLE
09-08-2007 | 06:13 PM
COSWORTH IDLE
my car idles better when i unplug thephase sensor how can this be
09-08-2007 | 06:22 PM
Sensor either faulty, or more likely incorrectly set up
JJ
09-08-2007 | 07:09 PM
Very odd, think I would start by checking belt timing markings, ie cam/dizzy/crank.
09-08-2007 | 07:18 PM
How can the car run without the phase sensor plugged in?
09-08-2007 | 07:27 PM
I've heard of cars running better with the Idle Speed Control Valve unplugged, but never the Phase Sensor??
09-08-2007 | 08:07 PM
the ecu doesnt look for the phase signal every rpm, only every 500 odd iirc
so if the engine is running you can unplugg it, then the ecu will make up the reading if its unplugged again iirc
10-08-2007 | 07:38 AM
It MAY revert to batch firing if phase unplugged.
10-08-2007 | 10:38 AM
have you got the sensors plugged in correctly phase to phase not phase to det sensor and det sensor to phase.
03-11-2015 05:08 PM
tonicosworth
Ford Escort RS Cosworth
31-10-2015 09:40 AM
15
07-10-2015 04:43 PM
Ade
Alloy wheels and ICE for sale
07-09-2015 06:06 PM
