3 bar map max reading
Old 09-08-2007, 11:38 AM
  #41
GARETH T
GARETH T's Avatar
tony's on form today
Old 09-08-2007, 11:43 AM
  #42
Turbosystems
Super Moderator
Turbosystems's Avatar
I have just logged into to simons mail box
inbox 8'7648972
outbox 0
sent items 0
Old 09-08-2007, 11:45 AM
  #43
GARETH T
GARETH T's Avatar
Old 09-08-2007, 11:47 AM
  #44
ECU Monitor Enthusiast
Tony,
At least my products are original and not modified versions of others work
Old 09-08-2007, 11:51 AM
  #45
Turbosystems
Super Moderator
simon your products are indeed very original so original infact that no one has one .
I wouldn't class your monitor as original these have been out since the mid 80's
Old 09-08-2007, 11:56 AM
  #46
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Originally Posted by T S M
when it eventially arrives I intend to install it zap back to 1973 and get a fookin refund roflol
I prefer this one - unfortunately it creates a paradox, because if you travel back in time and get a refund, this will mean Simon will cancel the order and you won't then get the Flux Capacitor however many years later, so then won't be able to travel back in time . My brain hurts from thinking about this paradox situation .
Old 09-08-2007, 11:59 AM
  #47
Physio
Physio's Avatar
Mike you're going to need a break after thinking that hard
Old 09-08-2007, 12:04 PM
  #48
Mike Rainbird
Caraholic
I'll have a Quick-Crap .
Old 09-08-2007, 12:05 PM
  #49
RichardPON
RichardPON's Avatar
inbox 8'7648972
outbox 0
sent items 0
FROFL
Old 09-08-2007, 12:07 PM
  #50
Turbosystems
Super Moderator
sent items 0
Old 09-08-2007, 12:08 PM
  #51
Turbosystems
Super Moderator
I'm going to stop it now not fair on simon
hmmmmmmm who shall i pick on next roflol
  #52
Physio
Physio's Avatar
Why?
Old 09-08-2007, 12:12 PM
  #53
Turbosystems
Super Moderator
Why?
good point
can't think y
I'll have to let some one else answer that
Old 09-08-2007, 12:16 PM
  #54
Eagle
Super Moderator
Eagle's Avatar
i recon there is such a thing as a flux capacitor they are less rare than a secs s8 ecu
and afr guages eh simon can't beleive i have missed such a great thread
Old 09-08-2007, 12:19 PM
  #55
Turbosystems
Super Moderator
inbox 8'7648972
outbox 0
sent items 0
yours must still be in his inbox or is it one of those in the sent items box ,definitely
Old 09-08-2007, 12:24 PM
  #56
JjCoDeX75
JjCoDeX75's Avatar
You guys crack me up!
Sorry if my post was misleading. I wasnt implying interpolation was a bad thing. As I understood it, the number of positions on the map of an L8 is fixed on the y axis (with the y axis being MAP). given that you have to map for 0-5v, you are constrained by the ECU technology as to how many different map settings you can select for value. BEtween these points, as I understand it, the ECU interpolates between the two valid points of data.
In my oversimplistic way, I assumed that becuase the 0-5v now has to cover 5 bars of pressure absolute, rather than 3, then the gap between these fixed points by necessity (assuming that you cannot simply add lines to the Fuel MAP) are greater.
I visualise this as a number of straight lines (joining points on a curve) to represent a curve. The further apart the straight lines, the more likely the interpolation is to be further away from the desired position on the map.
Is this wrong?
Sorry if I explained it badly!
JJ
Old 09-08-2007, 12:27 PM
  #57
RS500/364
RS500/364's Avatar
Simon is very helpful
UNTIL YOUR MONEY IS IN HIS POCKET !!
Old 09-08-2007, 12:34 PM
  #58
Turbosystems
Super Moderator
you have more chance of knitting snot than getting your goods rs500
Old 09-08-2007, 12:52 PM
  #59
aduz
aduz's Avatar
inbox 8'7648972
outbox 0
sent items 0
quality
Old 09-08-2007, 02:39 PM
  #60
foreigneRS
Testing the future
foreigneRS's Avatar
JjCoDeX75 that would be correct if the lines of the map had to go the full scale of the MAP sensor - but they don't. you can change the value to what you like
you could use the ecu for a NASP engine and rewrite the maps to use all of the breakpoints for up to 1 bar (absolute)
Old 09-08-2007, 03:15 PM
  #61
JjCoDeX75
JjCoDeX75's Avatar
I get that, but I was under the impression that the number of breakpoints is fixed?
That was the point I was trying to make
JJ
Old 09-08-2007, 03:17 PM
  #62
Turbosystems
Super Moderator
you only need a certain number of break points
Old 09-08-2007, 03:39 PM
  #63
foreigneRS
Testing the future
foreigneRS's Avatar
yes james, the number of them is fixed - but you only need to spread them out from -1 bar to +2.1 bar (for example). you don't have to spread them from -1 to +4 just because you have a 5 bar MAP sensor
Old 09-08-2007, 04:08 PM
  #64
JjCoDeX75
JjCoDeX75's Avatar
Okay - with you now.
But hopefully the point I was trying to make makes a little more sense though!
JJ
Old 10-08-2007, 09:47 AM
  #65
Turbosystems
Super Moderator
JJ
the number of brakes points can be altered up to a max of 16x16
Old 10-08-2007, 04:03 PM
  #66
JJ
Even more if you know what you are doing ...
Old 10-08-2007, 04:10 PM
  #67
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
on the topic of map sensors does anybody know how I power 1 up independant of the ECU to datalog with a LM1?
11 = sensor ground
30 = power?
15 = signal
I'm not too sure about how to go about it
any help would be apreciated.
Old 10-08-2007, 04:17 PM
  #68
You have to provide the map sensor with exactly 5 volts DC on the ground and power input.
The LM1 may have this available ?????
The signal output connects to your equipment.
Cant remember off hand the pin numbers for the sensor itself.
Alternativley....
You could data log of the existing sensor in the car.
Just connect the LM1 signal ground to the ecu pin 11 then pin 15 on
the ecu connector goes to the LM1 input.
Old 10-08-2007, 04:22 PM
  #69
Dan@Rapid-Ford
Alternativley....
cheers for the info mate
I didn't want to use the existing sensor as I don't want to mod the loom and want the unit to use on my other cars.
timsrs
13-11-2018 11:48 AM
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
SMILER258
28-09-2015 09:04 AM
jay030787
25-09-2015 01:38 AM
Quick Reply: 3 bar map max reading
