Adjustable Lower Arms for mk5/6 Escorts
does anyone make these???
i cant afford £150 on 2 new tyres every 2 months
i need to adjust the camber to pull the front wheels in slightly
Seen plenty of them in the rally game Also seen some proper ones fabricated up too......
It dosn't look such a difficult job to do either. I'll ask around for you, unless you have a spare wishbone to send me to play about with
i have a pair of wishbones mate.
that would be fantastic if you could sort something, also, if you did, i know alot of other people that would be interested in some.
not sure how much they need to come in by, but cant be much.
cheers mate
cheers mate
yeah, but it needs to pull the wheel in slightly aswell, cos its the inner edges that wear out quick, when they are lowered it screws the camber.
will rose joints chip my teeth lol???
Nuts where abouts near warrington are you as i drive round warrington most days delivering and i could drop you a pair of knackered arms off for you to mess with
Fudge how much is your car lowered and what size rims do you have??
simon
simon
Originally Posted by NUTS RuS
Knackered ones would be a waste of time - as they may be bent
Slightly north of Warrington Simon ..... do you get round Wigan much
and i can get to wigan no problem i live in atherton but work in A in M but we have a driver that delivers in wigan if you pm me where you want them sent i will send you a pair
simon
Originally Posted by fudgeass
mate, its lowered 40mm at the front, and running 205/40/17's
do you get this prob???
on my cabby, that was lowered 60mm and seemed ok???!!!???
simon
Trans Auto Sport (TAS) in Preston/Leyland sell adjustable T.C.A's similar to the one's you guys are after.....they consist of a modified standard arm with a double adjustable rose joint in place of the inner bush.....proper set-up requires the use of a compression strut, the removal of your standard anti-roll bar....bit expense...
HTH
HTH
jessie_rs
11
03-06-2019 04:57 PM
