running a mondeo TD on veg oil
I have a P reg mondeo TD - its the old Endura engine.
do i need to do anything to get it run on a veg oil mix?
start it with a blend, say 20% oil and 80% diesel
and see how it is from there
increase the dosing until you find the performance drops or the smell becomes too much.
be prepared to change the filters alot more often, and remember used vegetable oil is better than new
oh....and pay the duty on it (about 35p a litre), all the forms are available from
www.hmrc.org.uk
good luck
www.hmrc.org.uk
good luck
Originally Posted by Westy
if your going to pay the duty.. then whats the point..
who would know?
anyone ever had a tug from chip shop smells??
who would know?
Originally Posted by RWD_cossie_wil
Ok, in reality, who has a derv and has EVER been stopped for tank dipping etc?
It isnt good for th pump....
There isnt the lubruication in vegi oil that there is in diesel....
your better off buy bio diesel thats about 8p a litre cheaper than diesel and much better for the pump
Alex
Alex
Alex
Alex
its the same price as normal diesel where i live, in fact more expensive.
Team HOTHOT!
Its not the veg oil that is the problem for lubricating the pump.
Its the glycerine in the veg oil that thickens it up and causes problems with the pump. Hence you have to get the clycerine out with chemical reactions and such shite like that
Its not the vegi oil its the stuff in it??
who would know?
who would know?
You could use oil, pay for tax on a few litres a year, how they going to prove how much you have used
thats bullshit red derv is only for use for agricultual vehicles such as tractors and plant machinery, its untaxed and actually against the law to use it on the road vehicle unless its been approved, chip fat isnt against the law to use it just states that you must keep a record of it and tell the tax man at the end of the year, soo unless you have no common sense you cant get done, and as to thinking about actually paying the tax man WHY u might as well spend 1pound a litre on white!
If you get stopped with it- " this is my first tankfull, just trying it to see if it works "
RED diesel, is allowed to be used oin the road by those that are allowed mainly farmers etc.
My friend has been running HEATING OIL for 7 years, on his RANGE ROVERS, now on a 54 reg one without problem.
Every year at MOT time on his others he was told "JESUS IT RUNS CLEAN".
We add 2% KLOTZ TECHNIPLATE to the mix which works out at 11p a litre, spelt ELEVEN PENCE A LITRE.
Veg oil can be used without problem, but add a teaspoon of castor oil to every 10 litres.
Any yes it is UNDETECTABLE , as it has no dye in it, and heating oil is so much more refined than heavy crude(diesel), it comes from a slight different part of the tower to start with.
We had an engine that had over 200,000 miles on it always from day one run on heating oil, it also goes much better and does not smoke even when cold.
Buy your heating oil in the summer it's cheaper, my friend has a business and it uses heating oil, oddly the business uses as much oil in the summer as winter!!
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
ekjim
17-08-2015 08:57 PM
