computer geeks........
Old Jul 25, 2007 | 03:50 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default computer geeks........
how do i stop my p.c from dissconecting with the modem..???........i have to turn on bearshare (just an eg.),if i dont run a program it looses connection after about 20 ish mins..............bt homehub if that helps...if i turn bearshare on its fine...............cheers Pete
Old Jul 26, 2007 | 05:48 AM
pete mcrash
Old Jul 26, 2007 | 09:48 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Go into the configuration for the homehub.
You need to find the 'idle disconnection' time setting, which is probably set to 20 minutes - set it to 0 or -1 and it shouldn't disconnect when it's not being used.
bearshare is probably keeping the connection up by sending/receiving packets to its server.
Old Jul 26, 2007 | 02:17 PM
pete mcrash
thanks very much...................
Old Jul 26, 2007 | 02:31 PM
Thrush's Avatar
Thrush
Irritating c........
Yes, Bearshare will be keeping the connetion "Live" by constantly accessing the internet and recieving data, even tho you might not be down or uploading anything....
As said, go into the HomeHub settings and you should be able to fix the idle connection time settings in there......
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
