2bar MAP sensor V's 3bar MAP sensor question
Old Sep 26, 2004 | 05:58 PM
TIFF's Avatar
TIFF
Chasing Radders
Default 2bar MAP sensor V's 3bar MAP sensor question
This has always bugged me????
Why do people kick up such a fuss about cars running 28 psi+ on a 2 bar MAP sensor, as its out of its "Range"
BUT
You dont here people kicking up about people running 38 psi through a 3 bar MAP sensor, but isnt that out of the "Range" of that one too???
Old Sep 26, 2004 | 06:09 PM
SapphyMike's Avatar
SapphyMike
blinkers lol
Old Sep 26, 2004 | 06:18 PM
Matt's Avatar
Matt
Default Re: 2bar MAP sensor V's 3bar MAP sensor question
dont think you quite mean that now do you
Old Sep 26, 2004 | 06:30 PM
TIFF's Avatar
TIFF
Chasing Radders
eerrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Yep
Old Sep 26, 2004 | 06:33 PM
wimwerf's Avatar
wimwerf
BUT
38psi is out of range to with a 3bar map.
but how many people are boosting 38psi.....not many i think.
GARETH T's Avatar
GARETH T
i wouldnt never run boost over the top of my map sensors range
Old Sep 26, 2004 | 06:34 PM
TIFF's Avatar
TIFF
Chasing Radders
BUT
I think there is a few out there that are
Old Sep 26, 2004 | 06:37 PM
Karl's Avatar
Karl
Norris Motorsport
It's all down to how you map the car, such as using throttle multipliers as well as top line extrapolation. In an ideal wolrd we would'nt do this, but since not everything is ideal, there are ways around it that are very reliable.
I usually run anything up to around 6psi over the map sesnors range and find this causes no problems in terms of being able to map it. i.e. up to 23psi on a 2bar and 36psi on a 3bar.
Old Sep 26, 2004 | 07:12 PM
ECU Monitor Enthusiast
Running over the sensors range has multiple effects....
1) NO OVERBOOST PROTECTION.
E.G. Say you run 35 psi on a 3bar that only measures 29 psi then suddenly your
wastgate jams open and you get 40 psi = engine melt no warning.
2) OVER RANGE BOOST WEARS THE SENSOR OUT
A three bar sensor is designed for two bar of boost. If you continuously keep
stressing the sensor by over pressure you are reducing its usefull working life.
3 bar sensors are fragile even when kept in range from my experience.
3) ECU IS PRETTY DUMB
If the ecu is mapped for the boost out of range say at 35 psi and the sensor tops
out at 29 psi, all is ok if you run 35 psi but drop the throttle back a bit then the
boost tails off, if the boost is 32 psi then it is still getting fuel for 35 psi causing a
rich mixture. Some ecu's can overcome this but not many !
On my car, I run a 5 bar bosch sensor which can measure over 45 psi boost.
My normall running boost is 34-36 psi which is fuelled correctly and I have an over
boost fuel cut at 38 psi.
Also, I have closed loop boost control as the sensor measures the boost through
out the whole range.
Hope all this makes sense..
Old Sep 26, 2004 | 07:25 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
BUT
Old Sep 26, 2004 | 08:52 PM
TIFF's Avatar
TIFF
Chasing Radders
I knew you was one Angus
Old Sep 26, 2004 | 08:58 PM
Lee Reynolds's Avatar
Lee Reynolds
ran 28 on esc 2.5 std MAP.
Old Sep 26, 2004 | 10:12 PM
Matt's Avatar
Matt
BUT
Old Sep 27, 2004 | 08:29 AM
Jim Galbally's Avatar
Jim Galbally
tiff whilst i see the point you're making, consider this...
what "excuse" can you use for not running a 3bar map sensor at that boost?
"i was too pikey to buy a 3bar" is the only one i can think of
for 2+bar boost applications there are a lot more "issues" to resolve when not using a std marelli 3bar map sensor... so a lot more reasons to do things this way :P
whereas you're just too much of a gypo to buy a proper map sensor
Old Sep 27, 2004 | 11:25 AM
Matt's Avatar
Matt
jim, he runs a 3 bar you tart, he never used to on his stage 1 though and that caused a few issue for others
Old Sep 27, 2004 | 11:28 AM
Jim Galbally
oops, forgot he was on greys now
you know what i meant tho :P
Old Sep 27, 2004 | 11:46 AM
TIFF's Avatar
TIFF
Chasing Radders
Jim
You fookin TIT
Old Sep 27, 2004 | 12:08 PM
SapphyMike's Avatar
SapphyMike
i run 20psi on my 2 bar (thanks to Karl ), but i'll be having the stage 3 treatment next year with a 3 bar
Old Sep 27, 2004 | 01:08 PM
Jim Galbally
but mike, WHY do you use a 2bar instead of a 3bar?
if you had a 3bar sitting there for free you'd use it yeah?
Old Sep 27, 2004 | 02:24 PM
SapphyMike's Avatar
SapphyMike
Jim,
I run the 2 bar as Karl set it up with that.
I will be running a 3 bar when i go stage 3.
remember, my 20psi is stage 1.
Old Sep 27, 2004 | 02:30 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
This has been done for YEARS, so what is your point actually ?
Old Sep 27, 2004 | 02:31 PM
Jim Galbally
mike, i mean if you had a 3bar sitting there when you went to karl and its available to use if you wanted to at no extra expense... you'd have used it right?
Old Sep 27, 2004 | 02:36 PM
Mike Rainbird
Caraholic
Yes of course I would, but it seems as though Tiff thinks that running above 15psi or 30psi on each sensor respectively is something new .
I was running 19psi on my stage 1 chip before he was born .
Old Sep 27, 2004 | 02:48 PM
Jim Galbally
mike, wrong mike, i was after the northern monkey
Old Sep 27, 2004 | 03:10 PM
SapphyMike's Avatar
SapphyMike
Jim,
Of course i would, but if i had a 3 bar, i'd probably have greens to accompany them, therefore i wouldnt of gone for a stage 1
Old Sep 27, 2004 | 03:28 PM
TIFF's Avatar
TIFF
Chasing Radders
I dont think that running high boost on thses is new at all, i was just wondering Mike
People are quick enough to tell others that a 2 bar wont work right, but nothing is said to people running a 3 bar above its range.
PS- Im 26, do your maths old man
Old Sep 27, 2004 | 03:51 PM
Lee Reynolds
Tony TS didnt say it was daft Jimboy...and i was running light blues. 28psi on 2.5 bar map. Or is he a dumpling?
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
