help !! cant get oil pressure to turbo ............
just trying to get the cossie finished off and cant get oil pressure to the turbo feed pipe and cant get the light on the dash to go out
any ideas please ?????
span it over for so long the starter was red hot
Try filling the oil filter with oil or way over filling the engine turn over with plugs out so spins quicker and wont start failing that is the oil feed clear ?.
Regards Doug .
Regards Doug .
So long as your pump was working before just start it up it will pressurise in aboiut 5 seconds and do no harm so long as oil was used on bits during rebuild, there is so little strain on a idling engine.
Mine also would NOT prime on the starter with plugs out.
Overfilling will not do a thing, if the pick up is in oil as level is correct then it will make no difference.
Originally Posted by The Diva
Originally Posted by lloyd
take the dizzy out,put a drill with a suitable socket on the oil pump drive shaft,drive up the oil pressure.
Top method,works for me every time.....
Robbie sort your siggy out you Lord
had this problem with my new pug engine the other day..
i unscrewed the oil filter, put a oil hose over the threaded bit
that the filter screws onto..
funnel in the other end of the pipe, and just fill the oil pump up with oil.
it dont take very much oil..
it wil be the fact that the pump is dry that its not drawing any oil in..
(was with me anyway, oil pressure within a few seconds of cranking after i back filled the pump)
HTH
HTH
Matt Baxter
16-09-2015 08:30 PM
CrOwSoN15
18
22-08-2015 10:24 PM
mrmann
20-08-2015 11:24 PM
