inlet gaskets, fail proof solution?
Old Jul 18, 2007 | 08:20 PM
Mr C's Avatar
Mr C
Default inlet gaskets, fail proof solution?
I need new inlet plenum gaskets on T/body, plenum cover and possibly head, is there a way of making these replacements fit and forget, so they dont leak and will last a while?
Old Jul 18, 2007 | 08:31 PM
Butch.'s Avatar
Butch.
use a cometic gasket on the inlet to head and take apart the plenum and take off the throttle body clean all the old gasket off and get some sealant called TIGER SEAL and put this on both sides of the plenum and bolt it together with no gasket just tiger seal on both surfaces and it wont leak again i have done this many of times and it hasnt failed yet
Old Jul 18, 2007 | 08:33 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
it did on mine at 32psi
again and again and again
oh and its off again at the mo
its a swedish style one though
Old Jul 18, 2007 | 09:12 PM
zippyobrien's Avatar
zippyobrien
there was a thread about this about a month back, cant remember what the title was though
Old Jul 18, 2007 | 09:14 PM
Billabong's Avatar
Billabong
You could get them 'o' ringed...
Old Jul 19, 2007 | 09:14 AM
gibbo frst's Avatar
gibbo frst
my cometic ones are fine on mine.. with the plenum one i drilled through the threads and bolted right though bolts and lock nuts... has been ok so far..
Old Jul 19, 2007 | 09:19 AM
gibbo frst's Avatar
gibbo frst
i also had the plenum skimmed as it werent perfectly flat...
Old Jul 19, 2007 | 09:20 AM
Disabled Account's Avatar
Disabled Account
With the paper and cometic gaskets the key is to bolt through as gibbo says. Otherwise the plenum to inlet manifold bolts "pinch" or "bind-up" and you dont get the full clampimg force throughout the mating surfaces.
Old Jul 19, 2007 | 09:22 AM
RichardPON's Avatar
RichardPON
Really Mark? How come?
Old Jul 19, 2007 | 09:28 AM
Disabled Account
Who's Mark?
Old Jul 19, 2007 | 09:35 AM
RichardPON's Avatar
RichardPON
Mr C is Mark Doug.
He is the fella who purchased my track car and engine from me.
Old Jul 19, 2007 | 09:45 AM
AlexF's Avatar
AlexF
Mark Doug?
wHo's he?
Old Jul 21, 2007 | 05:46 PM
Mr C's Avatar
Mr C
Hi Richard how you doing?
Ive had the throttle body off for some mods, needs a gasket to go back on, just want to know if I can sort any problems befoer they happen, dont see a problem yet
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
