Steering Colum Cupling Replacment URGENT
Hi all, the above has failed my 2wd cossie for its MOT twice now! however, ford dont do it anymore and i cant get a thid party one.
This must have happened to someone of here, if so what did you do to source a new one? Withoput a replacment my car wil never pass its MOT!!
cheers all
cheers all
now i think i might need this as my steering has gone awful slack and takes a 2-3" turn of wheel before there is resistance
Hoping its something not tightened right after engine swap tho..
Originally Posted by col cos1
any 2wd sierra with pas will fit mate,ie gls ,ghia,
you can even adapt an xr4x4 1 without the bush to fit
get your ass to the scrappy Ł5 job done
can you explain this xr4x4 1 a bit? I just need a nw one from somewhere, can someone give me the ford part number? The cosworth one they dont do anymore, wil this be the same for th ghia gls etc?
lambchop il bet you a case of stella this is your problem,look down the side of the turbo and look at the end of the column it will be fecked
if this is the correct part you defo wont get the whole shaft new,this sounds stupid but they only came from ford complete but i bought mine as just the end part with bush brand new from a suppplier on ebay last year,i did post up his details before but its been that long i cant look that far back on ebay
think i was lucky though in getting it,but when it fucks up next i will be converting to xr4x4/4x4 saph one as its just a knuckle and no bush so will not fuk up easy
Which part exactly are you talking about ?
If it is the normal rubber that goes and cracks all over the place ?, the rubber from a LANDROVER DISCOVERY is nearly the same and can be used after taking apart etc, it IS available seperately as well.
Failing that a better cure is to use a metal joint welded on to make a double jointed shaft, these can be obtained from nfauto.com
4X4 one is too short to fit by a long way but can be made longer, for 2wd
Put one on my 2wd,got a welder to cut it down and re-weld it
Much better design with the two UJ's
so does the 4wd one have two cj'S? Please could someone measure the dimensions as im going to pick one up today but its of a normal sierra and i cant get a refund if it doesn.t fit. The garage cant take my old one of as their to busy today. Cheers
PRO-LINE MOTORSPORT
28-09-2015 10:54 PM
