Turbo failure questions!
Old 17-07-2007, 08:20 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
Default Turbo failure questions!
My T34.48 failed on session 2 at castle coombe a few weeks back,
i got the car home and havent touched it untill today
i knew the axail bearings had failed and the compressor wheel had touched the housing causing a bit of a mess
but i stripped it down today and found the exhaust housing has cracked in 6 places three cracks run straight through the wastegate port
the axial bearings have about 2mm of movement in them, which made the turbo stop working, but what would have made the housing crack like that? the engine is still A1, plugs are fine, nothing has melted but the EGT must have been well too hot to cause this?
any opinions?
it was peaking at 32psi holding about 28,
i dont want this to happen to my new maram shafted T34!
Old 17-07-2007, 09:19 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Thats a hell of a lot of boost for a .48 housing
Can't help, sorry
Steve.
Old 17-07-2007, 09:20 PM
mechanic28
mechanic28's Avatar
agree did not think a .48 housing would be able to handle this boost?
Old 17-07-2007, 09:21 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
camels
carl
Old 17-07-2007, 09:22 PM
JTECH James
Passion for Fords!
yeah you WIMPS! it fine stu spec'd me a chip to run it
JTECH James
Passion for Fords!
Originally Posted by G.B Turbo Solutions
camels
carl
is it normall then mate?
if so how could i avoild it? air leaking into the exhaust will make the closed loop go mental
Old 17-07-2007, 09:27 PM
mechanic28
mechanic28's Avatar
y do people go up to .68 housing then?just interested as i have got .48 housing was thinkin of going up to light blues but was not sure if the turbo would be man enough
Old 17-07-2007, 09:28 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Do you mean a .63 ????
Steve.
Old 17-07-2007, 09:29 PM
JTECH James
Passion for Fords!
they make the peak boost at a higher rpm, which increases the power ,380 is almost impossible with a .48, but 420 is possible with a .63
instead of the peak being at say 4000 rpm ,it would be at 6000
hence you get a bit more lag with a .63
Old 17-07-2007, 09:31 PM
mechanic28
mechanic28's Avatar
Steve.
urm maybe!
so if 380 limit on .48 housing then that is good enough for light blue injectors??
Old 17-07-2007, 09:32 PM
JTECH James
Passion for Fords!
would have thought so ,i use 55lb siemens injectors ,but they would also run a .63, and maybe even a T38, as they are bigger than greys
Old 17-07-2007, 09:34 PM
Mark_w
Mark_w's Avatar
whats the difference on the road...is it laggy???im just about to change from a .48 greens conversion which is responsive to a .63 greys conversion and im worried i will lose the driveability
regards mark
Old 17-07-2007, 09:36 PM
JTECH James
Passion for Fords!
well i have the .48, and its almost lag free tbh,
with the .63 yes you will deffo notice it wont make its power as quickly, but on the open road wont run out of puff at the top like the .48 does
it all depends on wht you use the car for really ,as a dialy driver and odd track day like me ,the .48 is hard to beat, off the lights its proper ace
Old 17-07-2007, 09:38 PM
mechanic28
mechanic28's Avatar
hmm so is there alot of difference between a stage 3 cossie and light blues i.e power,,accelration etc
Old 17-07-2007, 09:39 PM
JTECH James
Passion for Fords!
a similar difference betewwn a stage 1 and a stage 3 cossie
they peak and hold more boost
mine flys along!
Old 17-07-2007, 09:42 PM
mechanic28
mechanic28's Avatar
hmm maybe i will do it then if i canbe bothered to uprate my clutch from a standard one
Old 17-07-2007, 09:46 PM
JTECH James
Passion for Fords!
and everything else that will break
Old 17-07-2007, 09:48 PM
mechanic28
mechanic28's Avatar
why so ?itaint alot more then a stage 3 boost wise etc?
Old 17-07-2007, 09:54 PM
JTECH James
Passion for Fords!
i went to the 55lb set up ,and broke three gearboxes and front diffs in a year
so i had to spend 3.5k on a mullit straight cut box
turbos dont last that long at 32psi, well the last one didnt anyway
generaly the more boost you run the less reliable the car becomes
and then the brakes wernt good enough ,and so on and so on 15k lighter i still want more
Old 17-07-2007, 09:56 PM
BigErn
BigErn's Avatar
Lawnsy had the same problem twice recently, the wastegate arm was bending which ended up with the penny not sealing and it was stooooooopidly laggy and took a lot to make full boost. The resulting silly high temperatures which it produced trying to make its boost ended up destroying the exhaust housings.
Old 17-07-2007, 09:58 PM
JTECH James
Passion for Fords!
interesting one that!
mechanic28
mechanic28's Avatar
thats because it was .48 housing and was workin over time!!and mine 2wd so stronger the the chocolate MT75
Old 17-07-2007, 09:59 PM
JTECH James
Passion for Fords!
wait till you break it
or it rains
Old 17-07-2007, 10:00 PM
boXXer
GASH!
boXXer's Avatar
liking the wheels on your car mate
Old 17-07-2007, 10:01 PM
JTECH James
Passion for Fords!
i love them ,but they are only 7 inches wide ,so i have to sell them for some 8"s cos traction was a major issue on track
mechanic28
mechanic28's Avatar
or it rains
oh i c playing dirty now r we bout the rain!
Old 17-07-2007, 10:02 PM
JTECH James
Passion for Fords!
oh look out for the hedge
Old 17-07-2007, 10:06 PM
BigErn
BigErn's Avatar
JTECHSAFF what actuator do you run?
The problem with Lawnsys is cos he was using my Forge one, I dunno what the rating is but its running a white spring. To put it on with even the slightest tension it needed to be pressured up with a foot pump to around 45psi. We think its been under that much tension from the actuator that its bending the arm when its red hot.
Old 17-07-2007, 10:08 PM
mechanic28
mechanic28's Avatar
2wd easier to control when sliding then a 4x4 so there
Old 17-07-2007, 10:09 PM
JTECH James
Passion for Fords!
just a -31 mate, lots of pre load though
Old 17-07-2007, 10:10 PM
JTECH James
Passion for Fords!
tell me about it ,check my sig pic ,thats broadside on coombe
Old 17-07-2007, 10:11 PM
Matt
Matt's Avatar
Default Re: Turbo failure questions!
HEAT!!!!! lots of it
you're ringing the bollocks off the turbo
you could weld the wastegate shut and it wouldnt hold any more boost at high rpm!
Old 17-07-2007, 10:13 PM
JTECH James
Passion for Fords!
i might give that a go mate
Old 17-07-2007, 10:16 PM
mechanic28
mechanic28's Avatar
Old 17-07-2007, 10:23 PM
BigErn
BigErn's Avatar
JTECH James
Passion for Fords!
would have been ace if it had stayed on the track and not ended up on the grass
Old 18-07-2007, 09:41 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
camels
carl
normal,....people ringing the neck out of their turbos cause they dont want to spend money upgrading....YUP
usually find it in rsturbos mainly though
the amount ive thrown in the bin, my scrap man loves me
sorry i didnt reply when asked, i had to go somewhere and do something, what it was i cant remember
but as matt has stated below
Old 18-07-2007, 09:42 PM
abdr500
abdr500's Avatar
G.B Turbo Solutions
i sent you a pm did you get it
Old 18-07-2007, 09:45 PM
Carlsworth
Former Sponsor
Carlsworth's Avatar
Originally Posted by abdr500
G.B Turbo Solutions
bollox...
yes i did, but been busier than mr busy
forgot to reply, sorry
heres my reply to pm
start with a better turbo
**cough T3 **cough
Old 18-07-2007, 09:52 PM
abdr500
abdr500's Avatar
noooooooooooo it need to be the ihi one hybrided up as it will be way to laggy for a 1.4 engine i have tried befor
Quick Reply: Turbo failure questions!
