DYNO Figures the truth the whole truth......................
Happily retired
Theirs follows a summary of the good the bad & the ugly.
DAY1
Figures made 769bhp @ 7.5k
.....................556ft/lb @ 6k
at 2.5bar on a 40/42 Turbo (the big one)
To me these seemed good but over Supper Mark declared that the Spec was not working as the Turbo was surging & he could not get the boost in to get massive Torque.
DAY 2
I assumed we would return to the smaller Turbo we had bought but Mark decided to build a Hybrid from the two & just try it. First pull of the handle
had Mark more excited than a Jenna Jamison porno.
At 4.5k it was over 600ft/lb & still their at 6.5k peaking at 644ft/lb at 5k.
Power was about 30bhp up on the other combo throughout the range we monitored & the last recorded point was 741bhp @ 6.5k with a probable 1k still to reach peak, yes lads 800bhp from this for sure.(I will post the graph of the aborted run probably tomorrow)
Then the game came to an abrupt halt, the 7k point was 50bhp down & water was seen. Mark said head gasket. The pictures below show the actual problem & reveals Totb was over.
Thats a .005inch feeler the Liner has distorted & is .002inch proud of the block which caused the head gasket to pop as shown below, their is also damage to the head.
Thir isnt a lot of gloom in the MAD camp as Mark got a glimpse of the promised land (he was probably talking about Genna again) the engine Spec will be changed on rebuild as its far from optimum for the Fuel used.
I think I can speak for Mark when I say the next effort will make 800+bhp & 650+ torque off gas. This on the old Swedish exhaust & a spaced rs500 inlet which showed no signs of having reached its limit.
DAY1
DAY 2
Hi Rod
What a same i feel for you but when you are pushing sooooo far past the boundaries of anyone else these things will happen
It will be back quicker and better than anyone's
Russ
Russ
What a dissapointment
really feel for you guys as I know thats the last thing you needed.
Has the failure been caused by a machining fault or just that the liner cant take the power?
Happily retired
I am looking to change comp ratio and a couple of other small things for more power and TQ, Learnt a lot about the engine spec doing this but as a first go it was pretty dam sweet ,
I hope Rod will post the last graph as it looks good, 400ftlb 4k, 600@4.5k,640@5K, 640@5.5k 644@6k,600@6.5k Torque curve sweet .
Mark
I am looking to change comp ratio and a couple of other small things for more power and TQ, Learnt a lot about the engine spec doing this but as a first go it was pretty dawm sweet ,
Mark
bring on round 2
Caraholic
Rod,
How long before it is repaired (obviously not for TOTB), but for the top speed runs on Piston Heads etc?
Did it do any damage to the head as well, as the damage to the gasket looks horrible ?
Chin up, as it looks as though you have found a cracking turbo combination .
Mike Rainbird
About 2 months min, The head may get away with a skim if not a small weld all pistons look perfect but need to check no4 as this is the one with the distorted liner but I am now changing pistons spec's.
Mark
Mark
Mark
Guest
Posts: n/a
What a long day and 270 miles
Just so hoping it was going to be just the head gasket, but when we got the head of at Marks the damage was found
But after the group chat at marks look like the new spec is going to be the one
Did not get to run my inlet and marks new turbo manifold
See you tomorrow rod
Awesome power! Will be an absolute flyer on the road! Still can't wait to see what it can do again!
So sorry to see that kind of damage, keep it up, won't be long!
Football Cwazy
do you not think you're pushing things too far? I mean the figures are very impressive but it's another failure...surely you could just back things off a bit and get the car competing again? Hope it's sorted soon.
Guest
Posts: n/a
Rod,
However, you should have done what I said in my text yesterday, taken it off the dyno and stuck it straight in the car .
Dont think there would be much leaved of the engine if rod had also added 200bhp of gas as well
Very light damage this way
I am happy to run the engine at close to 1000hp so it was 25% under its max power.
Mark
Happily retired
Records are not set by normal bhp we need to progress not go back to safe territory. None of the bits that have failed are bits with MADs own input. The Block went after 40k miles when 900bhp was stuffed up its chuff & a liner from a company that does F1 blocks & Specced at 1000bhp has failed & needs investigating & a solution found.
