CoilOver's Question ?
Old Jul 9, 2007 | 11:00 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Default CoilOver's Question ?
Easy peeps,
Does anyone know the average spring rates for CoilOver's ? ? ? Gaz, AVO or anyother for a road spec kit ?
Mainly front rates I'm after but rears would be handy to know too !
Cheers in advance.
Jb
Old Jul 9, 2007 | 02:09 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
BTTT
Someone must know surely ? ? ?
Jb
Old Jul 9, 2007 | 02:14 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
JB, you would have thought that with the amount of serious Cossie guys into properly set-up cars on here, that someone would be able to answer your question.
Sorry I can't help!!
Old Jul 9, 2007 | 02:18 PM
Ridgey's Avatar
Ridgey
Well as a serious cossie guy, not.
My GAZ coilover came with (from memory), 300lb front, 200lb rear. Or there abouts.
Hope this helps
Dave
Old Jul 9, 2007 | 02:40 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i've just ordered a set of GAZ and for the best road set up...............it's a secret.. ..........no honest they wouldn't tell.........does it say on the springs.????.........i avn't got them yet.........
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Spring rates are entirely down to the damping rates of the shock absorber and also how you want the car to handle.
Having seen how you drive your car, I would suggest that you start with 325-350lb front springs and 150lb rears. This is based on you having AVO dampers. 200lb will be WAY To hard and cause the car to slide everywhere.
Old Jul 9, 2007 | 03:11 PM
AVO FRONT 300LB" 9"
AVO REAR 200LB" 12"
Ridgey's Avatar
Ridgey
GAZ kit comes with tags on the springs detailing rate, and a print out of the spring dyno graphs (no not BHP ).
Old Jul 9, 2007 | 03:13 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Christian, you know it man ! ! !
Thanks for the answer Dave, much appreciated ! Pete cheers for the offer fella !
Mike, I've jus ordered 325 for the front, but their LEDA on rear hence 2 1/2" springs but do have some travel in them now Only things that gave before were the tyres when the jumped up & down on the car !
The back will slide everywhere ? Is that a bad thing ? lol
Thank you VERY much for the info tho, can you get LEDA springs Mike ?
Jb
Old Jul 9, 2007 | 03:14 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
tabetha spot on !
Thank you,
Jb
Old Jul 9, 2007 | 03:35 PM
Mike Rainbird
Caraholic
Originally Posted by tabetha
AVO FRONT 300LB" 9"
AVO REAR 200LB" 12"
JB,
That is what they come with from the factory and in my opinion (having had this set up on my own car), the rears are too hard and the fronts too soft .
LEDA do not make springs, they have them made to their spec by outside companies. Personally, I use Eibach (which is one of the companies that they also use). Most companies that do 2ź" springs, also do 2˝".
If you go too hard on the rear, then you will not get any traction due to there being insufficient weight transfer. On track, 200lb is still a little too hard even (as an example, Martin's Escort runs 150s on the back!) and with my 170s, I have to have the damping on the lowest setting on the road and it is still fractionally too stiff (but I can live with it). Bearing in mind your car is 100kg lighter than mine, there is no need to go so stiff.
Old Jul 9, 2007 | 03:46 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
I see what your sayin & it makes sence ! ! !
Not sure the poundage on the rear at them mo, but I have got travel now !
Was thinkin bout 180's for the rear but she's stripped out & I cut the spare wheel well out too so quite light ! Might try get 150 lb then ! Thank you again Mike !
I ordered the fronts from Rally Design, they don't do 2 1/2" springs ! Anywhere else @ reasonable money for them ? Rally Design was Ł15 each !
Cheers Mike
Jb
Old Jul 9, 2007 | 03:54 PM
Mike Rainbird
Caraholic
As you have made the back end so light, then defo 150s .
Try Faulkners for cheep springs - they do 2.5" ID . You'll have to Google the number .
Old Jul 9, 2007 | 04:26 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Wicked !
Thanks again Mike you my hero ! ! !
Googling now !
Jb
Old Jul 9, 2007 | 04:28 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Mike,
There's like millions of Faulkners !
Any clues ? ? ? Cheers,
Jb
Old Jul 9, 2007 | 04:30 PM
Eagle's Avatar
Eagle
Super Moderator
i have 150 on rear and 350 on fronts.... leda's
Old Jul 9, 2007 | 08:12 PM
Mine at std spec from AVO are ace in my opinion, I trust their judgement!!
Old Jul 10, 2007 | 07:48 AM
Mike Rainbird
Caraholic
Originally Posted by jb fletch
Mike,
Jb
Yes, the length you want, in the size you want, in the poundage that you decide to settle on
Tabs,
Unfotunately just like nearly every single suspension manufacturer, they have not tested these dampers or spring rates on every single type of car that they sell a kit for, and just give it their "best guess" . Obviously sometimes they get it nearly right, but due to the way the rear trailing arm on a Sierra acts on the spring, they have gone too hard (obviously basing their calculations on the original spring rates). However, you have to understand, that by moving the spring further out, it doesn't need to be so hard due to the increased leverage.
When I get my car back on the road (which should be the end of this month), I'll take you out and you can see the difference in ride quality between mine and yours .
Old Jul 10, 2007 | 07:50 AM
Porkie's Avatar
Porkie
I had standard AVO stuff too years ago. I too thought they were fine. I now realise they were CRAP!
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
