what do i need for 500bhp
Just wondered what was needed on top of my current spec to break the 500bhp barier
205 block with wrc pistons 7.4-1 comp fully lightened and balanced
bd14's with uprated spring
ported and polished head with 3 angle valves and seats
High pressure oil pump
arp stud and nut kit
cometic head gasket
arp rod, flywheel and main bolts
helix 5 puk
Genuine 500 cooler
t4
greys
3 bar
l6 ecu
uprated breather system
cometic head gasket
helix 5 puk
Genuine 500 cooler
t4
greys
3 bar
l6 ecu
for what though????
Thats what i'm asking i know there not up for the job but is a 2wd inlet manifold also capable of 500bhp???????????? And i there any other bits of my spec that aint suitable for 500bhp
TT T38 Power
Originally Posted by Alps Pacino
for what though????
Steve.
DANISH cosworth abuser
cossiemanden
Its a 3 door so has 2wd manifold, also i think i might try the spacer plate on 2wd inlet and see how i get on tbh.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Increasing the volume gives better high rpm power, so good idea
cossiemanden
But will it acheive 500bhp plus? cause i thought it was the elbow that was restrictive???????
It actualy isent that bad
As covered by others you will need new injectors along with a different inlet set up.
IMO you will struggle with the L6, you should really be on a programable system.
get it running 2 bar and go measure the power
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Why is he gonna struggle with the L6 ?
It will make no difference to the engine power WHAT SO EVER...
Mine is over 500...
Ported head
NMS cams
Siemens injectors
Full Race T4
NMS Inlet
2 bar Boost.
7.5:1 CR
Mine is over 500...
Ported head
NMS cams
Siemens injectors
Full Race T4
NMS Inlet
2 bar Boost.
7.5:1 CR
I didn't know you could buy off the shelf chips LOL...
Used to karl doing everything to suite the car![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
L6 is not the problem making 500bhp its usually the t4 LOL
so what injectors will i need then???????
any other mods needed to the electrics
ignition system??????
will a 2wd inlet with spacer plate be ok????????
dingy
I see what your saying about the t4. The reason i started the thread was to see if 500bhp would be easy acchievable with a few more mods to me car, i'm not aiming for 500+ as such if you know what i mean
You never see a 2wd making over 450 normally so don't know on its bhp limits.
Normally people change the elbow on the 2wd by modding it or changing to small turbo escos.
I meant a off the shelf chip prob wont do, Didnt know you could live map L6? thought it had to be L8 atleast?
If you can map the car on L8 or L6 then its going to be ok aint it ?
Seen 500bhp on both ecu's LOL....
Franco
get it running 2 bar and go measure the power![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
what I am saying that you need complete control over the ECU.
