Help with radio problem - works van
Right my works van has got a handsfree kit ( nokia ) and radio is stuck on mute thanks to the plank who takes it home, its annoying the hell outta me driving all day in silence
Its a peugeot partner van, and its a standard peugeot radio, any idea how to get it off mute?
ELASTIC BAND
to prove its the nokia kit, pull the plug out of the nokia box, the 4 wired one, red, blue, yellow and black.
the blue wire is the feed to the radio to mute it duing a call
ELASTIC BAND
nope! but its abot 1"x4"x5" s and black
guessing it will be cable tied under the dash somewhere, can you follow the phone cable back to the box? or bt button
No its not..
The yellow wire is mute on a nokia kit, Blue is switched live.
It could be a number of reasons why its stuck on mute.
Does the sound come through the car stereo speakers? If so it could be that the relay is stuck inside the audio loom- it will need disconnecting to fix- but may happen again.
It could be the mute signal from the com box that is at fault- which means a new com box.
It could be the data cable from the holder that has gone wrong.
It could be that you have the 2 in 1 kit and he's tried pairing a samsung or other such phone to it and its crashed it- best to disconnect power from com box, reconnect and give him a slap.
It could be that the mute wire has earth on the chassis before it hits the com box which will cause constant mute.
Easiest fix untill you can get an engineer out to have a look or provide more details about what you actually have is as follows.
Remove stereo- 2 ford style/coathanger style keys in the 4 holes.
On the back or the radio is the standard iso connector. As you look down on it the furthest block away from you will have the yellow wire connected or bodged into one of the holes- If its bodged- pull it out and just replace the radio. If its connected properly just cut it with enough length so it can be re connected- make sure you insulate the end still connected to the stereo.
Hope this helps
Jake
Partner van- it will be either behind the air vent blank to the left of the stereo- it just pops off.
In the passenger foot well under the glove box cable tied/bodged into some wiring.
Above the stereo behind the vent- 3 x T20 screws to remove.
Jake
ELASTIC BAND
No its not..
Stu @ M Developments
41
21-08-2015 06:47 AM
