ceramic coating
Old Jun 28, 2007 | 09:51 AM
sbd16v's Avatar
sbd16v
Default ceramic coating
ceramic coated turbo exhaust manifolds
whats your experiances worth it ??
internal and external ??
or just external ??
trying to make my mind up if to get it done or not
Old Jun 28, 2007 | 11:26 AM
rapidcossie's Avatar
rapidcossie
AVA usually get their manifolds coated.
Makes quite a difference , even over wrapping.
Old Jun 28, 2007 | 12:26 PM
Badman38's Avatar
Badman38
Default Re: ceramic coating
or just external ??
my tubular manifold is off to camcoat for the cermakrome coating
sean
Old Jun 28, 2007 | 12:27 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
But as sbd16v says, what about inside?
I considered that, but just don't know if I dare with a £1500 turbo.
Old Jun 28, 2007 | 12:28 PM
gus's Avatar
gus
had my old one done and will be getting the new one done after dyno session
cools quickly after a thrash too
how much was yours to be done sean, what spec you get? inside and out?
Old Jun 28, 2007 | 12:50 PM
Bomber's Avatar
Bomber
Gus - what manifold are you using now?
Old Jun 28, 2007 | 12:51 PM
Badman38's Avatar
Badman38
dont know as yet i've told them my requirements but they will have a better idea when they Receive the manifold but here are some of there prices..
PRICES FOR COATING CUSTOMER EXHAUSTS EFFECTIVE 10TH APRIL 2002
GROUP NEW/USED FINISH MAX TEMP COLOURS
1 N/U Satin black 1000 Satin black for performance engines
2 N Polished 760 Cermakrome
3 N/U Matt colours 650 Aluminium,cast iron,blue-grey & dark blue
4 N Gloss colours 600 Red, white, blue, gold, silver,purple, yellow
5 N Satin black 1000 Full internal/external coatings to race spec
CAR EXHAUSTS Type GROUP 1 GROUP 2 GROUP 3 GROUP 4 GROUP 5
4 cylinder Cast iron £60.00 £81.00 £69.00 £75.00 £100.00
Short tubular £60.00 £84.00 £69.00 £75.00 £125.00
Long tubular £70.00 £94.50 £80.50 £87.50 £150.00
6 cylinder Cast iron £75.00 £101.00 £86.00 £94.00 £130.00
Short tubular £72.00 £108.00 £86.00 £94.00 £165.00
Long tubular £82.00 £124.00 £94.00 £102.50 £200.00
V6 cyl Cast iron £90.00 £100.00 £103.50 £112.50 £135.00
Short tubular £82.00 £115.00 £95.00 £102.50 £170.00
Long tubular £94.00 £132.00 £108.00 £117.50 £205.00
V8 cyl Cast iron £99.00 £134.00 £114.00 £124.00 £180.00
Standard bore £120.00 £168.00 £138.00 £150.00 £225.00
Large bore £140.00 £189.00 £161.00 £175.00 £270.00
Exhaust pipe £/foot Std. (to 1.5") £6.00 £9.00 £6.90 £7.50 £10.00
Larger pro-rata
Silencers from £40.00 £60.00 £45.00 £50.00 £50.00
Old Jun 28, 2007 | 12:55 PM
Neil@FastFord's Avatar
Neil@FastFord
I had Camcote do my manifold and turbo, good stuff.
Just dont mess with it or try to clean it as it will eventually flake off
gus's Avatar
gus
didnt know you can get the whole exhaust done
would that be worth it?
Old Jun 28, 2007 | 12:58 PM
gus's Avatar
gus
if your down toms anytime soon its underneath my engine, on the stand opposite yours
looks a little different to the norm that you see
Old Jun 28, 2007 | 01:00 PM
Badman38's Avatar
Badman38
definatly look polished
Old Jun 28, 2007 | 01:02 PM
Christian and Beccy
#1 in Spelling Club
Also, is it really good to keep ALL that heat in??
Surely EGT's will be higher and thereby risk other components failing?
Old Jun 28, 2007 | 01:07 PM
Kelv's Avatar
Kelv
Almost there!
i was thinking that.
Old Jun 28, 2007 | 01:14 PM
Rick's Avatar
Rick
Stupid idea. If you want to extract every last hp. then ok. But we're not racing, we're doing it for fun, and i prefer reliability than +3hp.
Old Jun 28, 2007 | 01:21 PM
Bomber's Avatar
Bomber
I'm not exactly local (Brighton) - i only ever go there to pay the bill and pick up bad news that the engines blown up
Old Jun 28, 2007 | 01:23 PM
Badman38's Avatar
Badman38
now your putting me off
Old Jun 28, 2007 | 02:18 PM
Christian and Beccy
#1 in Spelling Club
Well, we often see car's where the customer has gone to great lengths to heatproof everything and generally on car's like that you can expect EGT's to be considerably higher. It really is a fine-balance. I am fairly sure that my manifold won't be wrapped, but I will use heat-proofing materials to protect the area's close to this major heat-source.
Old Jun 28, 2007 | 02:35 PM
Badman38's Avatar
Badman38
are they dangerously high, so do you think its worth doing i guess to plus i have never had a problem with heat but while the cars in bits i thought i would have the manifold coated.
Old Jun 28, 2007 | 03:33 PM
Rick's Avatar
Rick
it basically has the same effect as running lower octane fuel...
Old Jun 28, 2007 | 05:19 PM
escossie560's Avatar
escossie560
I could be barking up the wrong tree, but how is coating a manifold going to raise the egts as at the velocity the gases are moving on full chat i would not see you getting alot of cooling effect from air over your manifold any way and egts reading would be a truer figure of what is leaving your engine so would be a better indicator of what is going on if there was much of a differance.
Old Jun 28, 2007 | 05:23 PM
Rick's Avatar
Rick
air cooling has nothing to do with radiant heat.
Old Jun 28, 2007 | 05:43 PM
Badman38's Avatar
Badman38
so you would advise against me just having the manifold coated.
thanks
sean
Old Jun 28, 2007 | 05:45 PM
escossie560
so how does this raise the egts leaving the engine
Old Jun 28, 2007 | 08:14 PM
sas's Avatar
sas
should be good!
I have done some back to back testing using ceramic coated manifolds (Zircotech) verses standard manifolds.
The outcome was - coated manifolds cracked but lowered underbonet temps.
S.
Old Jun 28, 2007 | 08:25 PM
Rick's Avatar
Rick
thanks
sean
If it's not a competition car where every last hp counts - then no.
escossie - do you mean how does coating raise the EGT's? If so, a ceramic coated manifold will not allow heat to be radiated out of it. The heat and energy therefore stays in the exhaust gas, and it does not drop in temperature.
Simon - kind of confirms common sense - but nice to see u have tested it properly
Old Jun 28, 2007 | 10:52 PM
escossie560
I see what you saying about radiant heat but that is only surface temp of manifold not gas temp ,as the main aim of whatching egt is to monitor head/cylinder temp so you dont destroy your pistons or head the manifold temp is after this point so now only protecting your turbo.............so my piont being that depending on sensor position you may read a higher temp with a ceramic coated manifold i personally cant see there being that much difference with the gas velocity at full chat but even if there is a differance what is in danger as even with the manifold coated the gas temp from the head is the same, not being argumentative just trying to understand your point
cheers andy
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
Matt Baxter
Sep 16, 2015 07:19 PM
jonfoc
Sep 11, 2015 04:46 PM
