Twin carbs for xr2...
Old 26-06-2007, 09:49 PM
Sean_RS
Sean_RS's Avatar
Default Twin carbs for xr2...
Been thinking of buying some twin carbs for our xr2 track car... new set is quite expensive. Been looking at some recon second hand ones. Is it worth bothering? what is entailed? do we need to uprate fuel pump etc...?
Old 26-06-2007, 09:54 PM
mechanic28
mechanic28's Avatar
you mean u lookin for a set a dcnf's 45?i had them on my xr2!
Old 26-06-2007, 09:55 PM
Sean_RS
Sean_RS's Avatar
weber twin 40 dcoe carbs
Old 26-06-2007, 09:57 PM
mechanic28
mechanic28's Avatar
they r the side draughft ones aint they?u lookin at 40 or 45's
Old 26-06-2007, 10:03 PM
Sean_RS
Sean_RS's Avatar
40... dont know a massive amount about them tbh
Old 26-06-2007, 10:07 PM
andyescos
andyescos's Avatar
If you want it for the noise then yes, but otherwise it's just not worth the hassle. Get a proper carb for it instead.
Andy
edd
edd's Avatar
depends the tune of the engine really....
Old 26-06-2007, 10:11 PM
Sean_RS
Sean_RS's Avatar
We just want to get the most power out of the engine as possible but dont want the unreliability of sticking a turbo lump in at the moment.
Old 26-06-2007, 10:29 PM
smitsturbo
smitsturbo's Avatar
allot cheeper & nicer to go for bike carbs nowadays
Old 26-06-2007, 10:40 PM
Sean_RS
Sean_RS's Avatar
sounds interesting... do u know anybody who has done it and what sort of results they had?
Old 26-06-2007, 11:10 PM
Rick
Rick's Avatar
bike throttle bodies on megasquirt.
I'm mapping a rally car on them soon.
Old 26-06-2007, 11:22 PM
Sean_RS
Sean_RS's Avatar
sounds costly...?
Old 27-06-2007, 12:14 AM
spi escort gti
spi escort gti's Avatar
if you go on ebay you can pick up a set of r1 throttel bodies for 50 to £80
get a inlet manafold bracket made and if you want loads of bhp get a DTA ecu not cheap but the ecu itself can hold upto 300bhp plus and it controles everything
and you will need make a wireing loom for your car to go in the ecu sounds hard work but not that bad my mate use theses set up on their kit cars /westfields
you should easy pull 40 bhp plus
Old 27-06-2007, 07:32 PM
Sean_RS
Sean_RS's Avatar
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
sridgett
01-10-2015 07:30 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
Quick Reply: Twin carbs for xr2...
