HELP with brakes
25-06-2007, 05:24 PM
25-06-2007, 05:29 PM
try a mk 5 rs2000
25-06-2007, 05:48 PM
If it has std Escort handbrake then its the Mk3/4 front yoke and as said above the RS2000 Mk5 rear end. Your better off if you mix the two
25-06-2007, 05:54 PM
no its a sierra handbrake
25-06-2007, 05:59 PM
you would need a mk5 rs2000 cable mate
25-06-2007, 06:03 PM
Super Moderator
25-06-2007, 06:04 PM
cool cheers
is that a deffo from everyone cus ill order them tomorrow if it is
25-06-2007, 06:07 PM
Quote:
Originally Posted by magic randy
cool cheers
ive got a rear engine fiesta ,what disks did you use on the rear?
25-06-2007, 06:24 PM
ive used granada hubs discs and calipers
26-06-2007, 01:07 PM
I've used chevette clutch cables in the past in conjunction with Granada / Cossy rear calipers on my rally car. Nicely adjustable as well
26-06-2007, 01:11 PM
mk5 rs2000
have you converted the car to rwd ???
26-06-2007, 02:15 PM
Super Moderator
you only need the rear part of the cable .. the bit that goes between the calipers...
26-06-2007, 09:10 PM
ive ordered the rs 2000 cables now
will have to see whether they fit tomorrow night
yeah "turbo" its RWD
26-06-2007, 10:14 PM
i take it your using a sierra handbrake lever?
either way you need to change the half moon clip to the one suited to the handbrake depending on which car it came ff
27-06-2007, 10:59 PM
will i fitted the rs2000 cables, had to cross them over from left to right unlike the sierra ones i took off all lined up ok but the handbrake didnt meet up
so i made a extender
cheers for your help
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
