are rst cps sensor interchangable?
Old Jun 22, 2007 | 06:50 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default are rst cps sensor interchangable?
need one for my rs as i have the hole there but can only find zetec ones will these fit cvh engines? if not anyone got a cvh one?
Old Jun 22, 2007 | 07:08 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Crank/Cam position sensor? ERST's dont have them....
What cars is it on? and EFI I take it?
Old Jun 22, 2007 | 07:09 PM
Rab's Avatar
Rab
Fucking superstar........
Crank position sensor Dave.
And Roosie, yeah mate, they're all 36-1 same signal voltage.
Old Jun 22, 2007 | 07:14 PM
Roosie's Avatar
Roosie
ok cos im sure the mondeo ones look difference
Old Jun 22, 2007 | 07:20 PM
Rick's Avatar
Rick
if it will physically fir, then it will work.
Old Jun 22, 2007 | 07:21 PM
Roosie's Avatar
Roosie
what gap there goto be from sensor end to grooves in flywheel
Old Jun 22, 2007 | 07:24 PM
Rick's Avatar
Rick
1mm
Old Jun 22, 2007 | 07:42 PM
xr4x4rs's Avatar
xr4x4rs
the zetec sensor is a short stuby little thing and a frst/efi cvh uses a long sensor
zetec one wont register as its too far away from flywheel
cvh one you need the bracket that goes on the block for the cps to go too
if you dont use the bracket the cps is to long then and the flywheel will chew it up
i also think that the 2.0 dohc injection from sierras sues teh same cps as a cvh
well all mine dohc has used long sensors
Old Jun 22, 2007 | 07:50 PM
Roosie's Avatar
Roosie
what bracket? i have the hole there remember its a cvh block im putting it on
Roosie's Avatar
Roosie
do ford still do them
Old Jun 22, 2007 | 07:59 PM
xr4x4rs's Avatar
xr4x4rs
on the cvh thers a little cylinder type bracket
the bolt for this bracket goes in from flywheel side
then the cranksensor goes into this block into the flywheel
dont know if ford do them or not
be easier to go find a efi cvh down the scrappy
Old Jun 22, 2007 | 08:26 PM
Roosie's Avatar
Roosie
there all missing from the unit in my local scrappy
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
