part number for an original oil filler cap?.....
22-06-2007, 04:28 PM
14000+ post superhero
and are they still available from ford?
thanks.
22-06-2007, 04:32 PM
I bought a 4x4 one not so long ago so this part should still be available, not too sure on 2wd cap
Luciano
22-06-2007, 04:33 PM
Quote:
Luciano
not the same cap then?
22-06-2007, 04:37 PM
2WD (as in your sig') is a bayonet fitting, 4x4 is screw fitting.
2wd use a baynot type and 4wd use a screw type
22-06-2007, 04:50 PM
More boost Igor!
22-06-2007, 04:59 PM
anyone got a spare bayonet one i can have cheaply? mine currently has on old vw one on at the moment as its all i had at the time and it doesnt quite seal properly causing oil to run down the rocker cover
22-06-2007, 05:40 PM
More boost Igor!
Mine's an original one mate, and I have an oil leak from there too. Was gonna make up a gasket out of Weetabix box, see if it solves it
The 4x4 (89 model year onwards
) one i bought has a nice thick rubber ring around the top to seal it.
22-06-2007, 06:06 PM
I have a brand new one never even out of the packet, for 2wd.
I will see if I can decipher the part number for you.
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
31-08-2015 11:02 AM
da52rkn
Ford Focus Range
21-08-2015 04:41 PM
Michael Wisbey
14-08-2015 11:57 PM
