3 door wont start?????????????????????????
hi all cars in for mot tommorow went to start it and it wont fire.
there is a spark to all 4. there is fuel to the rail but the injectors are not working could anyone shed any light on what could be causing this. any help much appreciated.
Moderator
Could it be fuel pump?
Im pretty sure when you switch the ignition on that you should hear it prime up? if not that could be your problem.
I obviously could be totally wrong as im not an engine specialist whatsoever, but theres loads on here and hopefully one of them will help you out!!
** edited** just seen youre getting fuel to the rail so probably not pump then :-(
Indyrs
20
01-09-2015 09:04 AM
borboyous
22-08-2015 11:17 AM
saph in dorset
14-08-2015 10:10 AM
