Sensible amount of boost for this spec?
What would you guys say as for a safe amount of boost to run?
was peaking at 32psi, had it turned it down to 29 peak is this about right?
Standard cosworth engine running on 10w 50 silkolene pro s
Multi layer head gasket
t34 with 63 housing
grey injectors
pro alloy rs 500 intercooler and rad
Ford headbolts
909 motorsport ignition leads
MSD chip
14mm plenum spacer
All new top ends gaskets and valve stems
New timing belt
Bailey breather system
Uprated samcos hoses (every hose)
Swirl pot
plenum spacer
Rewired fuel pump
Ap organic clutch
82 degree thermostat
All new sensors (tps, air temp, water temp)
Ford 071 spark plugs
forge dump valve
Group a coil
vibretech engine mounts
cheers in advance
t34 with 63 housing
grey injectors
Ford headbolts
MSD chip
14mm plenum spacer
New timing belt
Swirl pot
plenum spacer
Rewired fuel pump
Ap organic clutch
forge dump valve
Group a coil
cheers in advance
without checking,, NOTHING is a safe amount of boost
if the car was mapped for 32 psi,, that is your limit and that what i run on the same sort of spec engine as yours
BTW, if it was mapped for 32 psi, and you have turned it down to 29, your engine will be running a little richer
Originally Posted by pete mcrash
i think u'd be better off speaking to ur tuner,cos people on here will argew all day long.....whats boost does it hold.????
saff is working!!!...atm
PassionFords Creator
It was brought direct from you i believe stu
1) Ask for the instructions that came with it.
2) Give me the serial number and engine spec and i will give you a close idea.
Originally Posted by SapphyMike
whats wrong with using the phone nowadays?
Yes but it dont solve my question does it, you could have called them for me by now and posted up the answer
besides, the time you've wasted replying to me, you could've called
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
