Can you change a gt30 from external to internal wastegate
Just wondered as i have a gt30 sat there for my golf which is externally gated but i'm thinking of slapping it on the cossie but wouldn'y mind making it a simple install by making it internally gated.
Ps the turbo is brand fire new suplied by reyland, so is a decent unit
#1 in Spelling Club
Just fit an Internally 'Gated Turbine Housing. These are quite pricey though and rarely come up second-hand. You are most probably looking at the wrong side of Ł200, maybe even closer to Ł300 for a new proper Garrett housing.
That said, I have 2 sizes of Internally 'Gated T25/T28 flanged GT30 Turbine Housing which may be up for sale in the not-too-distant future.
So basically it would probably be just as cheap buying the external gate manifold and 46mm wastgate from reyland and the jobs a buck.
What do you do about the pipe from the gate, is it just a open ended bit of pipe or does it need to be flanged into the downpipe?????????
Noisy when it comes on boost or noisy when just driving normally. My cossie is a road car so i dont want it as loud as fuck cruising on the motorway to shows etc. Plus who the fuck does screamer pipes??????
*** Sierra RS Custard ***
its loud whenever the wastegate is open, so not until when you are running quite a bit boost.
JK12
33
26-04-2021 12:09 PM
