overheating
Old Jun 4, 2007 | 06:44 PM
AlexF's Avatar
AlexF
Default overheating
Ok its not a Ford but its an odd one!
My other half's MGF has had an overheating problem which I posted about on here before but I can't find the old thread... but anyways
So far I have replaced the following:
Thermostat - modified to allow bypass
Radiator
Pressure Cap
and as of today the HG (uprated Land Rover spec)
Guess what!
It still isn't right!!!!!!! Its the same as before
Leave the engine to idle and the engine comes up to temp. Then the temp increase to the point where the radiator fan kicks in. This doesn't cut out and the temp guage keeps rising (along with the level in the header tank).
So its definitely going to over heat if left to its own devices.
The crazy thing is that if you increase the revs to say 1750 (or even 4000! it makes no odds so long as your above idle) the temp guage and level in the header tank drops down to normal... Let it idle and this just repeats!
I'm left with thinking its the water pump even though it looks perfect and feels fine it's the only part I haven't replaced!!!
Alex
Old Jun 4, 2007 | 06:47 PM
xr4x4rs's Avatar
xr4x4rs
could be a lazy water pump mate
as you are increasing the revs the water is dlowing faster so the pumps kicked back into action
if it still does it once you have replaced the water pump then could be a crack in the block or head
but then id imagin you get oil/water mix and it would run like shit
Old Jun 4, 2007 | 07:50 PM
Does sound like the water pump
the vanes have probably worn down
Old Jun 5, 2007 | 10:20 PM
AlexF's Avatar
AlexF
Well it wasn't the water pump!!!
So now I am checking sensors and pipes as that is all thats left - unless I start to suspect the block itself as thats soon to be the only common bit left
Old Jun 5, 2007 | 10:35 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
A work mate owned a tf that overheated with the roof down,could be related?
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
