Computer people, advise is needed please!!
I am in the process of finishing my new study which use to be the 3rd bedroom, the problem being is that my internet line comes into the house downstairs into the living room, Can you recommend me a good wireless router which I can plug into my line down stairs and will give me a good signal to my new pc upstairs ??
As above, and you just don't need the super expensive high speed things either - 54M is fine as it's still much faster than your internet connection.
The only time it makes a difference is when you have 2 PC's on your network and you are trying to copy huge amounts of data. I just plug a cable in then...
Irritating c........
You actually have two choices here - you can go for a wireless router to send the internet signal from the downstairs ADSL point to a wireless reciever in the PC upstairs, or you can use something called HOMEPLUGS.
Homeplugs are basically a plug that fits any wall power outlet, and uses the electrical wiring to transport data signals. Basically, it turns your house wiring into one great big network! You plug on in downstairs, connect it to your modem via ethernet (cat5) cable, then plug another one upstairs and connect it to the PC using another ethernet patch cable. The modem recieves the internet signal, sends it to the homeplug, which sends it to the other homeplug(s - you can use more than one!) anywhere in the house, that then connects to a PC
Brilliant invention, and they can do 85mps - much faster and more stable than wireless. No limit on the ammount you can use either, so you can have an internet point in EVERY room in the house - even the shed/garage!
I'll be getting some myself soon I think, as I'd like to extend my internet to other rooms without having to run cat5 all over the place
I like the homplug idea.
Or altrenatively get a Netgear. JJ on here told to chuck my rubbishy linksys one away and get a netgear one.
Piece of piss to install and pretty faultless!!!
Testing the future
i also have a netgear one with matching netgear wireless card in the pc. was very easy to setup and gets 99% signal strength and runs faultlessly. mind you, the pc is in the room above where the router is, but my squeezebox on the other side of the house also runs faultlessly from it
I now have a linksys wireless router after having no end of problems with my old Netgear one. Its been ok but the signal was quite weak. I've put a signal booster in the loft which has helped but still not 100% happy. Will be changing my ISP from Pipex soon to see if the internet outtage is them being fookers!!
Chris
Chris
Never been a fan of Netgear's, but people seem to like them. Whatever you do though, don't under any circumstances buy anything Belkin. Absolute shite!
I recommend either Linksys routers ot Draytek routers. Drayteks are well pricey though, but thats what i install for customers wanting VPN connectivity into their businesses from home.
Linksys are cheap and cheerful, and work like a dream. I have a Linksys WAG54Gv2 at home and cant fault it.
Originally Posted by MattRS1600i
I have virgin cable ( formerly telewest ) and netgear just doesnt work
bought a second hand linksys from an ebay shop for £15 and its rock solid
Am i really pmsl like you know what i'm doing?!?!?
I had a mate telling me there was no way his router would work with Telewest, and that he had been on to their tech support and they had told him the same.
I went round and spent 5 minutes on it, and it's been fine since. That was about a year ago
How are you setting up the internet connection?
Netgear DG834GT is a good wired/wireless router.
I dont trust wireless. It's easily crackable if you know what your doing. I use my neighbours connection if our line is maxed out downloading porn!
I'm not saying netgear stuff doesnt work with old telewest/virgin i'm saying it didnt work in my circumstances
We think the problem was with the cards not the router but the linksys was a temp fix that has been rock solid so has never been changed.
Originally Posted by cozmeister
The best one I've used so far is a Draytek 2800G, pricey, but worth it
First few months after 2800 was launched, on certain ISP's (Zen mostly) they wouldnt sync at anything over 5mbit
Still prefer the 2600G over the 2800G...but thats me, havent got used to the new menu layout on the 2800s yet
Originally Posted by BigMouthBillyBass
I install and support networks for small/medium sized businesses, every so called technical/IT director i've ever met hasnt known their arse from their elbow
I had D-Link G604T when i lived at my mums a few years back, had no end of problems with the wireless, used to drop every hour or so and fail to reconnect itself. So you find that you set a big download going, leave it overnight, come back, and find out that the wireless had fallen over 10 minutes after i'd left it
I thought it was the D-Link PCI card but tested with an HP laptop with Broadcom wireless chip. Same problems
I moved out and left it there, piece of junk Luckily my parents PC is sat right next to it so it's connected through cat5
kosienutter
31
22-08-2015 09:55 AM
