cossie no spark
Old 28-05-2007, 05:58 PM
Dicko&Vacant
Dicko&Vacant's Avatar
Default cossie no spark
as some of you mite know my engine was fooked
so its just been fully rebuilt etc put it all back in today getting all excited as you do pull ht lead off crank engine over to get oil round check timing again all spot on
so here goes put ht lead back on and crank it over and it dont fookin start got no spark at all
so any ideas what will cause no spark the only thing thats been changed is ive put a brand new 4x4 dizzy in but had to use my phase sensor, put new cap and arm on aswell.
Old 28-05-2007, 05:59 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Have you got the crank sensor and knock sensor plugs the correct way round - they are easily plugged into the wrong connectors as they are next to each other and look identical
Old 28-05-2007, 06:12 PM
Alvyn
Alvyn's Avatar
check phase sensor plug's the right way round?
Old 28-05-2007, 06:15 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Originally Posted by Alvyn
phase sensor plug the right way round?
It can only go one way.
However, inside the dizzy, make sure the phase sensor wires are the correct way round
Old 28-05-2007, 06:16 PM
Dicko&Vacant
yes mate as i marked every plug before i stripped it lol plus i dont think mine has a knock sensor its 2wd if that makes any difference
Old 28-05-2007, 06:17 PM
Ryan
Ryan's Avatar
wont have a knock sensor if 2wd.
Old 28-05-2007, 11:12 PM
coszee21
coszee21's Avatar
i had the same problem mate and i found out tht one lil wire from fuel pump to ecu was bad and wasnt sending a live feed so car was a cabbage after replacing the whole loom it was alive and kicking
open up ecu and check all live feeds are live if not u could pin point ur prob
hope this helps
zee
Old 28-05-2007, 11:33 PM
Ginge !
just finding my feet
Ginge !'s Avatar
check mapsensor and cps,,,, they would also cause no spark
Old 29-05-2007, 07:21 AM
Map will not cause lack of spark just bad running.
Phase sensor can be wrong way on older ones the top wire of the two brown wires goes to live on the connector on the dizzy side, obviously on new ones it is red to this live.
Check your gap at the phase and cps AFTER you check you have put in the ROTOR ARM, I have done it loads of times!!, coil connected as well
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
deathrider666
28-09-2015 06:12 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: cossie no spark
