Removing a dump valve.
Old 22-05-2007, 02:02 PM
  #41
Chip
*** Sierra RS Custard ***
Chip's Avatar
Originally Posted by Billabong
In my experience, removing the dump valve does sharpen up throttle response when going back on the gas. The theory behind that is you haven't just dumped most of the pressure from the IC (which would then have to re-pressurise).
Obviously in some turbo / high boost applications, you'd ideally need to run a dump valve to prevent catastrophic turbo stall to due a massive pressure reversal.
If there's a difference after removing the DV such as increased boost, then that's probably as Chip said re: leaks. That doesn't necessarily mean that it had a leak when the boost was set, as up to a point, a turbo will do its best to supply the pressure it's set for - which in the case of a leak, could mean the turbo overspeeds whilst trying to supply the set boost level (which again is a danger point)
Also the pumping losses will be different during that leak, so the engine wont be emptying its cylinders as well, so when it was mapped to the correct AFR, if you remove the leak then you have a situation where it will lean out and also may detonate due to the timing now being too agressive.
All in all a VERY dodgy sitation to be in, really you need to remove the leak and have it remapped.
Old 22-05-2007, 02:03 PM
  #42
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
If you use a decnet dump valve in the 1st place it wont leak. Problem sorted
Old 22-05-2007, 02:09 PM
  #43
Billabong
Billabong's Avatar
Not if the leak wasn't there when it was mapped (and I'd hope that a mapper would check for such things prior to mapping), but arose later on (e.g. damaged DV diaphragm). The turbo will then - up to a point - try to compensate and still try to supply the boost it's set to (and then possibly overspeed itself).
Old 22-05-2007, 02:17 PM
  #45
Chip
Chip's Avatar
If there wasnt a leak when mapped, it would be unlikely to cause a misfire when you removed the leak.
Old 22-05-2007, 02:27 PM
  #47
Billabong
Billabong's Avatar
My apologies, I should have put the latter part of my original reply in a different paragraph and made it clearer that I was simply talking about the dangers of a damaged DV, and not the misfire.
Of course there's always the possibility that someone could have tweaked just the boost after noticing a drop in boost level, without actually finding the reason for the boost drop. Then at some point, the DV is removed/replaced and then boosts higher than previously as there's now no leak.
Old 22-05-2007, 02:29 PM
  #48
Chip
Chip's Avatar
Old 22-05-2007, 02:35 PM
  #49
Billabong
Billabong's Avatar
Old 22-05-2007, 02:38 PM
  #50
cozmeister
More boost Igor!
cozmeister's Avatar
At any other time you dont want the entire boost of the turbo to squueze past the throttle.
But without a dump valve, the boost has nowhere else to go, ergo, more boost = quicker throttle response That's what I was trying to say That's how I understand it anyway.
Old 22-05-2007, 02:39 PM
  #51
Chip
Chip's Avatar
Without a dump valve the turbo slows down because there is too much resistance for it to keep spinning, and while its doing this it makes the potentially damaging chattering happen.
Old 22-05-2007, 02:47 PM
  #52
morto
morto's Avatar
this is how it works..
you like dump valves ..you keep it on
you dont like dumps .. ya take it off
job done
andy
Old 24-05-2007, 05:26 AM
  #53
SS1
SS1's Avatar
chip so are you saying turbo chatter can cause damage ?
my cars got a recirculating dump valve.but it does still chatter
even on the lowest boost setting ?
found this on wikipedia
Dump valves are fitted to the engines of (usually older) turbo charged cars and sit between the turbo outlet and the throttle body. When transitioning from a boosted state to a closed throttle state (as in between shifts), due to inertia, the turbo continues to pressurize air, but the closed throttle prevents the compressed air from entering the engine. In this case the pressure exceeds the preset spring pressure in the dump valve and the excess pressure is bled off to atmosphere.
Even with a dump valve the compressed air acts as a brake on the turbo (slowing it down), because the pressure on the backside of the turbo is at a higher pressure than on the front side (and the air actually wants to flow through the turbo backwards).
i know the chatter noise is the air passing backwards through the turbo blades.but im still confused
Old 25-05-2007, 01:14 AM
  #54
4x4
4x4's Avatar
chatter sounds gooooood.
i dont know anyone on here in person but i can be satisfied in thinking tis Mr Ford is this phil person. Chip-3dr has put some very valid and technical advice but mr ford denies them or ignores them and its obvious to pf users that theres some kind of problem between the two.
i think chip 3drs posts on technical issues are very helpful so as a new comer why would mr ford just write him off
Very sad, a grown man acting like a child
boeb
09-01-2020 05:11 AM
DAZZER
30-09-2015 08:43 PM
Orion_Gav
29-09-2015 04:50 PM
Quick Reply: Removing a dump valve.
