jump starting
Originally Posted by Dan@FastFord
wont it bump?
An old trick is to take the battery off the bike if not going to be used for a few months and see if you can put it at the end of your car battery, maybe with tie wraps etc then connect up by making leads for it, then it gets used all the time!!, failing that connect up to another supply ie ciggy lighter to exercise it.
PF Idiot Sniper
Originally Posted by tabetha
So long as it is the correct voltage it will be ok, might have a problem actualy fitting clips onto batt terms though as they are a lot smaller ?
Mate just bought proper bike jump leads that are way smaller. V handy!
Next time buy a battery trickle charger
DixieTheKid
11
06-06-2020 11:20 AM
