Gearbox noise..........
Ex Ford Man
I press the clutch pedal fully down and i can hear a whinning nosie coming from the gearbox........its only when i press the clutch FULLY down. Lift it up and little and it stops.
Also, a update on the gearbox..... I can now get gears 1-5 but still have trouble engaging reverse. Can get it manually but not with the gear stick.
just an idea, as when i did my first xr2 turbo conversion, put a brand new clutch in, along with the release bearing, and it was really really noise for a week, despite it being fitted as per normal- it quietened right down after!!
Also is the box done up tight and true to the block, I had a gearbox fitted by quite a well known garage and only three bolts were holding the box on, when the pedal was pressed the clutch would make a noise , which later became a screech after the bolts worked loose!!!
This was with a brand new box and clutch
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Ex Ford Man
Originally Posted by Ryan
not a clue.
complete stab in the dark but, paddle plate wrong way round?
can you hear whereabout in the box it is? flywheel end? gear end?
Gearbox is all tighty done up, not loose.
Didn't think it matters which way round the paddle plate goes
Ex Ford Man
Both sides looked the same
chowfornow
14
05-01-2019 09:01 PM
