What are the best pistons for a 2.1ltr ZVH engine?
As above please.
If anyones had any bad or good experiences please let me know.
Thanks
Matt.
Thanks
Matt.
How much you want to spend?
Best: Custom made ones like Arias(?) etc
VFM: Set of vauxhall calibra pistons. Either new or with a couple of hundred miles on from PhilM. Aparantly these have a tendancy to do the ring lands over 300bhp.
I used to think RS200 pistons were good, BSW used to use them (not in mine) but on chatting to Karl they are skimmed too much to get desired CR and there isn't enough meat on them.
I'm sure someone more technical will be able to fill you in.
Didn't even bother going for the MOT mate.
I'm not actually sure what the problem is with the engine yet.
It could be 1 of a number of things: Turbo, Pistons, Head Gasket etc.
Personally i think its the new turbo or head gasket, but i'm going to strip the engine down tonight which should tell me where the oil was coming from.
I'm just after opinins on the pistons encase it is them.
I've been told JE Pistons are the best.
Originally Posted by Rossco
Iam using Accralite pistons in my 2.1 16v Zetec turbo
Have you ever had any problems with them??
Do you know the date they were manufactured?
Matt.
I already have the Accralites in my engine, but have been told they tend to fail.
I'm just wondering what other pistons are avaliable for this engine and what peoples experiences are.
Matt.
Matt.
Matt.
Matt.
I thought that they were a prety good piston
Matt.
Matt.
It was the early Accralite pistons that had a problem so yours will be fine.
This is the email from them yesterday:...
Originally Posted by Accralite Pistons
Dear Matt,
Thank you for your enquiry.
The design of the Zetec piston has changed now, as you probably know the
first Zetec pistons were very thin skirt.
Now they have a lot thicker skirt, which makes them heavier but still
lighter than the original also a lot stronger.
If you require any further information please do not hesitate to contact us.
Regards,
Lisa
On the behalf of Accralite Pistons
Regards,
Lisa
Matt.
Rstar_man
143
20-07-2020 11:16 PM
blackbeautyzetec
11-09-2015 03:10 PM
cossiedean84
37
02-09-2015 10:19 PM
ekjim
17-08-2015 08:57 PM
