Any issues using a ST esc cos head on 2wd saff?
Testing the future
the ST uses the 2 coilpacks in the middle of the head - not a problem if you have a coilpack conversion (although the subloom will need to be modified - ryan has supplied a subloom for that before)
Water Temp Sensor.
The brass temp sensor for the guage reading is in the head in the middle between the pulleys.
other than that its pretty straight forward, u will probably need some custom leads if u want to use the spark plug cover aswell.
Originally Posted by Lambchop
Stu
So what all would i need to run wasted spark using a ST head? Discussed before i know but im simple
http://cgi.ebay.co.uk/Cosworth-Waste...QQcmdZViewItem
Or you could get some ST YB coils and run those instead of teh coil in that pack... but i would need to have you a special loom made up.
Shit the bed!
I appreciate its a great bit of kit but i can NOT afford that as well!
Bottom end...ENOUGH
New head...£500?
Gaskets+belt...£270
500 ic...£320
Ins...£500
Tax...£100
MOT...£150 if lucky?
Tune...£100
Fuel(run in)/oil...£200
I need the car done LATEST 9 weeks on fri and think i've got enough to spend
Dont get me wrong im not scrimping on it, im also paying my wedding which is on that deadline day!
Bottom end...ENOUGH
New head...£500?
Gaskets+belt...£270
500 ic...£320
Ins...£500
Tax...£100
Tune...£100
James Porter
28-10-2015 12:17 PM
FlashRS
13
31-08-2015 06:02 PM
ekjim
17-08-2015 08:57 PM
