central locking
Old May 2, 2007 | 12:37 PM
ricky's Avatar
ricky
Default central locking
how do iget in with out cassing any damage car as been fully de-locked my alarm been playing up so its gone back to manifactor i add left one of the rear doors open so i could gain access now one off my e.d.o.t. m8 was messing with front door handle and now all 4 doors are locked so how do i get in 4x4 saff
Old May 2, 2007 | 12:42 PM
Phil79's Avatar
Phil79
Brick + Window = entry
Have mate pay for window for messing around
Old May 2, 2007 | 12:44 PM
BillyCabrio's Avatar
BillyCabrio
W.T.F.?
Wheres Mr Mulheron when you need him
Old May 2, 2007 | 01:15 PM
dojj's Avatar
dojj
Resident Wrestling Legend
get underneath
open the bonnet
disconnect the battery
reconnect it and soemtimes the central locking will cycle once
otherwise, window time
do a rear as they are easier to replace and don't put the glass everywehre as much
Old May 2, 2007 | 01:19 PM
xr4x4rs's Avatar
xr4x4rs
dont know if its worth shot
but under the boot floor at tha bck ( i dont know if the fuel tank is covering it) thers a grommet that the wires come through to go to the tank and fuel pump
push the grommet through and it should be wide enough to get a solid stick or something in there and try and unlock the boot relase mechanism inside as ots juts a slider
if not then your going to have to do some damage or make your self a car break in kit to get behind the door and unlock it from inside
Old May 2, 2007 | 01:41 PM
Eagle's Avatar
Eagle
Super Moderator
fone the aa ..
can get you in the car in under 2 minutes
Old May 2, 2007 | 01:44 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Jump leads on starter motor
Old May 2, 2007 | 03:04 PM
ricky's Avatar
ricky
if i can get underneath to open the bonnet it wont be a problem i can leave bonnet open and when alarm comes back i can connect it and open door but at the moment the car is hard up against the garage door so very hard to get undernaeth
Old May 2, 2007 | 03:29 PM
IANS2RST's Avatar
IANS2RST
pull open the petrol cap, undo the self tapping screw & filler cap.
then carefully prise out the fuel filler cap assembly then you wil be able to get to the combined boot release/filler cap remote cable. pull this to open the boot, then crawl througt the back seats
Old May 2, 2007 | 03:52 PM
BILLY's Avatar
BILLY
Originally Posted by Eagle
fone the aa ..
Agree
Old May 2, 2007 | 04:13 PM
xr4x4rs's Avatar
xr4x4rs
thats actually quite a good way as the cap is only stuck in buy some double sided foam
Old May 2, 2007 | 04:34 PM
Another way, get some door locks, or see a con as they can get into these in less than 30 seconds, or a repo man.
Old May 3, 2007 | 02:38 PM
ricky's Avatar
ricky
finally got two wire coat hangers
joined togeather ,realease boot leaver preasto ,cimed into
boot open door job done
thanks for all those people who came up with a few sudjestion
in the end a coat hanger did it 4me
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
